mgroeger
Hurricane, UT
Yea,
You can’t get the part separate, In that thread or this one.
In that thread we talk about the after market part you are wondering about.
1996cc
Oregon
21 JLUR 392
There is only one rear main seal. It’s on the back of the motor. A lot of 3.6’s have them go bad.
mgroeger
Hurricane, UT
No one knows if they are updating that part. Supposedly FCA is very aware of the problem but the fact that an aftermarket company (Z Automotive) beat them to a fix two months ago is pretty pathetic on FCAs part.
Seriously, this isn't rocket science.
Roky
Roky
I have my lockers wired to my aux switches almost 2 years now, if that part goes bad will it not affect the hot and ground? If it does, the z locker fix won’t work either since it’s plugged in externally, or am I missing something?? I probably am, I’m always missing something....:facepalm:..., lol.
mgroeger
Hurricane, UT
You, my friend, have done what I am about to do because I'm tired of the BS the lockers come with. By doing what you did you have eliminated the problem. The two wires that come off the sensor that are failing go to the computer module/switch to tell it the state of the locker. They have no physical tie to the hot and ground to my knowledge. In doing what you did you are completely bypassing the system. It's no different than on my wife's Jeep where we run them to the AUX sw. because they are an aftermarket install.
Right now my Sway Bar switch isn't working and the locker rocker switch is shot so I'm having that replaced under warranty.
After that, if problems continue, I'm wiring to AUX switches and putting this BS to bed.
mgroeger
Hurricane, UT
It's impossible to get all of the metal silt out of the oil without some sort of filter. It is what it is... a crappy part prone to leakage. Nothing will change until that part is revamped.
No IFS
So Cal
JL Rubicon
So just to be clear, at this present time there is NO replacement part. just a aftermarket bypass to make locker work.
mgroeger
Hurricane, UT
Figure out a way to buy this...
Jeep Wrangler JL JL Rubicon owners: keep your locker sensors from failing! How to pot your sensors 1598374415907
No IFS
So Cal
JL Rubicon
Yea,
It’s like asking a politician questions.
OK. So the answer is NO you cannot buy a replacement part at this time no matter how many threads I read.
Got it
mgroeger
Hurricane, UT
Got it
All of your questions had been answered numerous times in the thread so it was the teach a man to fish idea since the answers were all there.
If you had read the threads you would see there is a part and people are trying to find a way to buy it, hence why I told you to find a way to buy it. You would also see that another guy is trying to get 25 people together to order the part in bulk from a supplier. The answer is not NO, the answer is people are working on a way to buy it.
You can get frustrated at yourself for not reading or you can call me a politician even though I pointed you to the answers.
