dajuicejml
- Justin
- Nov 1, 2017
- North Carolina
- 2018 JLRU
TitaniumAre these titanium or matte black 309s?
Any more pics of a stock suspension 2 Door JL with 285/70/17s on any 700 series Methods? Front, side shots? Bonus points for a Rubicon with highline flares. Ordered the 701s for my new Rubicon and worried the stock tires might look skinny after a little poke is added due to the wheels.Method 704s aren’t too shabby in titanium. That’s just my opinion. Just went to a 285/70/17 tire and noticed the Jeep automatic shifting just a little sluggish.
Nice looking Ride..Another vote for the Method MR703 in Matte Black. I selected a wheel spec that matches what companies like AEV and others use to get the performance characteristics I'm currently looking for. I went with the Method 703s for weight savings, performance and looks vs the other brands I shopped.
17x8.5
5.78 Backspacing
25mm Offset
Wearing BFGoodrich All Terrain TA K02 tires.
37x12.50R17
Load Range D
First trip out on the new wheels and tires. Before and during some off-road fun.
Do I need to buy a new set of lug nuts for these wheels? Or I can use the stock ones.Another vote for the Method MR703 in Matte Black. I selected a wheel spec that matches what companies like AEV and others use to get the performance characteristics I'm currently looking for. I went with the Method 703s for weight savings, performance and looks vs the other brands I shopped.
17x8.5
5.78 Backspacing
25mm Offset
37x12.50R17
Load Range D
The Method wheels use spline , at least the 700 series doDo I need to buy a new set of lug nuts for these wheels? Or I can use the stock ones.
Can you tell me what lift you are running in this pic?18x9 Method Grids
37x13.50 Toyo M/Ts
That was just an EVO 2.5” boost w falcon shocks and the teraflex control arm relocation brackets. Didn’t swap the coils.Can you tell me what lift you are running in this pic?
Also, if I had known how much wider the new axles were on the JLs, I would have went with 12.50 tires. The 13.50s were a little wider than I prefer.Can you tell me what lift you are running in this pic?
Did you ever swap out spacers for coils? If so why?Also, if I had known how much wider the new axles were on the JLs, I would have went with 12.50 tires. The 13.50s were a little wider than I prefer.
No. I thought the ride quality was as solid as stock and I didn’t wheel that Jeep so I was happy with the spacer performance.Did you ever swap out spacers for coils? If so why?
thanksCan you tell me what lift you are running in this pic?
