JL Offset & Backspacing Finally Answered!
SSinGA
Sean
Alabama
2020 JT, 2018 JLUR, 2016 JKRHR, 2012 JKU Sahara
  • JL Model: JLU Rubicon
  • Wheel: Raceline 928M Monster 17"
  • Offset: -12
  • Backspacing: 4.5
  • Tire Make: Cooper STT Pro
  • Tire Size: 37x13.5x17
  • Lift: Rock Krawler X-Factor 3.5"
  • Rubbing: Full turn on lower control arm (very slight)
  • Like
Reactions: J0E
SSinGA
Sean
Alabama
  • Offset: -12
  • Backspacing: 4.5
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 9B7B9FC9-C7FF-4FDF-BDA7-FFCD21BFEADA
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! D6EF5C73-0F57-4533-B9F2-B514EA59D056
I’
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
20 Unlimited Altitude, still have stock wheels and1.5 inch spacers till wheels and tire arrive. Problem is not sure about the wheels yet. Tires will be 37.
JL Model: Sport Altitude
Wheel: Stock 18” Altitude wheel
Offset: +44.5
Backspacing: 6”
Tire Make: Goodyear Wrangler Ultra Terrain AT
Tire Size: 275/70R 18
Lift: Clayton off-road 2.5+ overland
Rubbing: Yes with the lift this is why the 1.5" spacers. Clayton says 4.75 backspacing for their lifts.
Pictures:
PillowFightr
Sam
Arizona
2021 Jeep Wrangler Rubicon Diesel
Data Center Engineer
I was hoping to see the KMC XD231 RG Race (0 offset) and KMC XD232 RG Race (-38 offset), but i cant find much info about them :(
Those are the only 2 wheels i like and i dont think ill be able to fit the -38 onto my rubicon diesel, i think it will rub! I might just go with the 0 offset version!
This thread is amazing, hopefully more people post their configs and pics here! 😎
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Try this thread. It’s not diesel but still Rubicon’s.
https://www.jlwranglerforums.com/fo...dlocks-dirty-life-dts-etc.65763/#post-1392613
JL2021guy
JL2021guy
Daly City
2021 Jeep Wrangler rubicon 3.6
Jeep fun
[*]JL Model: JLUR
[*]Wheel: gfx tr 10
[*]Offset: +12
[*]Backspacing: ~5.5
[*]Tire Make: mastercraft courser mxt
[*]Tire Size: 37 12.5 17
[*]Lift: mopar 2.5-3
[*]Rubbing: super mild on inner fenders when off roading. Not enough to be bothersome
[*]Pictures:
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! IMG_4116
i wasnt aware mopar has more than a 2" lift. do you mean that the 2" lift gives more than 2"? i will have to look into this more...
Tdkrum5
Ted
WA/AZ
JL Model: 20 JLU Altitude with Rubicon D44 axles
Wheel: Teraflex Nomad
Offset: 0
Backspacing: 4.75
Tire Make: Nitto Trail Grappler
Lift: Clayton Off-road 2.5 plus overland lift. I got around 3"
Rubbing: None at this time with minor flexing . Sport fenders are a little narrower cause of smaller axles. Waiting on the Rubicon High line fenders before I really test it out. Also have the Terafles front sway quick disconnects.
Pictures: From the driveway
InMyImage
Bill & Britt
2019 Rubicon JLU
Legitimate questions, not trying to be rude or flippant... examples of what people are running is interesting but there aren’t any “answers” in this thread.
We are going to attempt to afford solid upgrades for a trip to the Rubicon Trail next summer and would like to actually make it through it.... We have a stock 2019 JLU Rubicon and are looking at 37” tires with beadlock rims and a 3.5 lift that requires a backspacing of 4.75 or less but doesn’t specify an offset so what would be good guidelines for the rim offset for common wheel widths?
Thanks
  • Like
Reactions: J0E
GATORB8
CLT NC
21 JLURe
Thanks
Offset and backspace relationship changes with wheel width. Actual wheel width is 1” wider than nominal. Offset is the movement in the mounting face from the center line, so dead center is 0mm offset.
so… a 8.5” wheel is actually 9.5” wide, 0 offset would be a backspace of exactly half, so 4.75. So you need an offset of 0mm or less
A 9” wheel would be 10” wide, so 0 offset is 5” BS. You need at least 1/4” less which is about 6mm, so you would need an offset of -6mm or “less”
InMyImage
Bill & Britt
2019 Rubicon JLU
Thanks! That’s really helpful, appreciate it and enjoy your weekend.
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
I wish I had found this thread when I was shopping for wheels and tires!
  • JL Model: Rubicon
  • Wheel: Ballistic Rage
  • Offset: -19mm
  • Backspacing: 4.75
  • Tire Make: BFGoodrich Mud Terrain KM3
  • Tire Size: 325/60R20
  • Lift: AEV DualSport 2.5”
  • Rubbing: None
  • Pictures:
  • Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 9943A5F4-17CE-49CD-839F-0397FE5EAB14
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 108D44B3-0DCB-40DA-96AD-9D71BCC8F48E
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! E40899BB-C13D-4E18-9777-9D62ABE20864
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 4440079B-2FAF-40B2-B6FF-FA4E78FA5748
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! D0798741-DC3B-4510-8CC8-18B5FC80E778
GATORB8
CLT NC
21 JLURe
Guess I may as well post our setup while I'm here.
  • JL Model: JLUR 4xe
  • Wheel: Raceline Clutch 17x8.5 (934B)
  • Offset: +18 mm
  • Backspacing: 5.46
  • Tire Make: BFG AT KO2
  • Tire Size: 35x12.50R17
  • Lift: 2" F, 1.5" R, 2" Bumpstops
  • Rubbing: Front: full lock full stuff minor on aftermarket front bumper
  • Pictures:
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 30C6C7EB-1935-47EA-86E9-760E6BF95CFC
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 076E0653-228A-4120-BBF8-51DA57EF6D70
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! C3AD0709-B0C8-4136-8A58-0CB65F8A98D7
2019 JLUR
Anoka, MN
2019 JLUR
This thread really does not give anyone any good information without telling us how much bumpstop front and rear. Rubbing or not rubbing is usually because of the amount of bumpstop.
