JL Offset & Backspacing Finally Answered!
Yovwmon
Adam
OH
Wrangler JL Altitude
And the answer is - it’s complicated. (Read on)
The offset & backspacing debate has many right answers due to variance in what folks like and what actually works. The endless combination of wheels, tires and suspension plays a major role in the confusion. With your help this thread will become the JL Wrangler Forums “Go-to” for the offset & backspacing answers we’ve all been asking.
Instructions: Please copy and paste the below template into your reply and fill in ALL the fields.
  • JL Model: (Specify Rubicon, Sport or Sahara)
  • Wheel: (Specify Make & Model)
  • Offset: (Specify millimeter number and +/0/-)
  • Backspacing: (Specify in inches)
  • Tire Make: (Specify Make & Model)
  • Tire Size: (Ex, 285/75 17)
  • Lift: (Specify number of inches)
  • Rubbing: (Specify where and when)
  • Pictures: (Add images that show wheels/tires from the front, side and rear)
Yovwmon
Adam
OH
  • JL Model: Sport Altitude
  • Wheel: Stock 18” Altitude wheel
  • Offset: +44.5
  • Backspacing: 6”
  • Tire Make: BF Goodrich KO2
  • Tire Size: 275/70R 18
  • Lift: 2.25” Rubicon takeoff w/.50 leveling kit
  • Rubbing: No rubbing anywhere
  • Pictures:
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
  • JL Model: Rubicon
  • Wheel: 17x9 KMC XD138 Brutes
  • Offset: -12mm
  • Backspacing: 4.53"
  • Tire Make: Milestar Patagonias
  • Tire Size: 38x13.50
  • Lift: 3.5" Metalcloak Gamechanger 6-pack edition/Synergy hybrid
  • Rubbing: Rear pinch seam (not yet trimmed)
  • Jeep Porn:
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 20200815_110338_resized
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 20200813_083445_resized
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 20200815_110458
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 20200813_083706_resized
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 20200813_083632_resized
blnewt
New Mexico
Just ask @cosine he knows!
Hard act to follow there Mike @Headbarcode :( But here goes~
  • JL Model: (Specify Rubicon, Sport or Sahara) Sport S 2dr
  • Wheel: (Specify Make & Model) American Racing ATX Ravine (hubcentric) 17x8.5
  • Offset: (Specify millimeter number and +/0/-) +10
  • Backspacing: (Specify in inches) 4.7
  • Tire Make: (Specify Make & Model) Milestar Patagonia
  • Tire Size: (Ex, 285/75 17) 295/70/17
  • Lift: (Specify number of inches) 2" Rubicon Suspension Swap from JLUR w/ Hardtop, Tow and Steel Bumper pkgs
  • Rubbing: (Specify where and when) Plastic Euro fender inserts at full lock, since removed.
Pics 1 thru 5 are without any lift, pic 6 is w/ Rubicon Suspension Swap, pic 7 &8 is w/ Stubby bumper & winch (190 lbs total added) for a 1/2" drop in front.
EDIT*****Last pics in current form w/ high fender kit & Fox 2.0 shocks (0 to 1.5" lift set)
ChattVol
Tennessee
JLU 4 door
  • JL Model: Rubicon
  • Offset: -12mm
  • Jeep Porn:
Looks great...How many bumpstops? Would love to hear feedback after you wheel it and flex it fully. I've read where others have had solid rubbing with fender chop on the front inner liner & frame/brackets wheelin hard with 38x13.50 tires on 17x9 with 4.5 backspacing wheels. I'm running 37x12.50 Pats with 17x8.5 wheels with a backspacing that measures 4.6 with 2" bumpstops and it rubbed hard on the frame/brackets under the fender at full droop with 29" of extended shock in front. The axle shifts quite a bit when one side droops alot and you stuff the other side...I was surprised. Your crazy long travel 6 pack shocks will shift the axle even further.
This where I had heavy rubbing up front.
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! IMG_20200802_192536_893
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! FgCC5D8
ocrejects
Orange County, CA
2021 Rubicon, 2018 JLU Rubicon, 2018 Tiguan SE
  • JL Model: Rubicon
  • Wheel: 17x9 Fuel Beadlocks Covert
  • Offset: -15mn
  • Backspacing: 4.5
  • Looks great...How many bumpstops? Would love to hear feedback after you wheel it and flex it fully. I've read where others have had solid rubbing with fender chop on the front inner liner & frame/brackets wheelin hard with 38x13.50 tires on 17x9 with 4.5 backspacing wheels. I'm running 37x12.50 Pats with 17x8.5 wheels with a backspacing that measures 4.6 with 2" bumpstops and it rubbed hard on the frame/brackets under the fender at full droop with 29" of extended shock in front. The axle shifts quite a bit when one side droops alot and you stuff the other side...I was surprised. Your crazy long travel 6 pack shocks will shift the axle even further.
JL Model: Rubicon 2018
  • Wheel: 17x9 Fuel Covert Beadlocks
  • Offset: -15mm
  • Backspacing: 4.5”
  • Tire Size: 37x12.50x17
  • Lift: 2.5” Rock Krawler
  • Rubbing: very little, Rear Back plastic finder liner. Took off. No issues anywhere else.
blnewt
New Mexico
  • Offset: -15mm
  • Backspacing: 4.5”
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 1FE44BCC-9DF9-4882-A821-E8C056B3A105
Just dippin your toe in the shallow end I see :)
NICE!
ChattVol
Tennessee
JLU 4 door
  • JL Model: Rubicon
  • Offset: -15mn
  • Backspacing: 4.5
  • Offset: -15mm
  • Backspacing: 4.5”
Nice! Any full flex pics? How many bumpstops? I had wheeled mine several times previously without any bad rubbing until I hit full flex.(one rear tire came off the ground) My shocks are also the RK 3.5" twin tube shocks that extend to 29"...that also contributed. I think 17x9 with 4.5 backspacing would be ideal with 37x12 50. With 38x13.50, I think it takes backspacing closer to 4.0 to clear at full flex. Mine also bottomed out here with rear tire 39" lifted:
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! WSBuDtu
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! IUoJ1Uo
sourdough
left coast
JL
  • JL Model: rubicon
  • Wheel: AEV JL Pintler
  • Offset: 5.77 +25
  • Tire Make: cooper stt pro
  • Tire Size: 37x12.5r17
  • Lift: mopar approx 2.75
  • Rubbing: eleminated rubbing at rear liners with heat reshaping and front LCA's with steering stops out 1/4"
  • Pictures:
  • Jeep Wrangler JL JL Offset & Backspacing Finally Answered! JL w new shoes 2
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! JL tire stick out
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! JLR flexed frt
    Jeep Wrangler JL JL Offset & Backspacing Finally Answered! JLR flexd rear
ChattVol
Tennessee
JLU 4 door
  • JL Model: rubicon
  • Offset: 5.77 +25
  • Pictures:
Nice...love those tires. 37s will clear with wheels with higher backspacing with the mopar lift bc it doesn't have alot of travel. I think front shocks only extend to 26". What did your jeep score in that flex test?
Yovwmon
Adam
OH
  • Wheel: 17” Fuel Nitro
  • Offset: -12
  • Backspacing: 4.25
  • Tire Make: Goodyear Duratrac
  • Tire Size: 315/70R 17
  • Rubbing: No rubbing anywhere under normal road driving. Vehicle rides incredibly well, very stable and these D load tires feel so much better on bumps than what the BF Goodrich Ko2 E load did.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
[*]JL Model: JLUR
[*]Wheel: gfx tr 10
[*]Offset: +12
[*]Backspacing: ~5.5
[*]Tire Make: mastercraft courser mxt
[*]Tire Size: 37 12.5 17
[*]Lift: mopar 2.5-3
[*]Rubbing: super mild on inner fenders when off roading. Not enough to be bothersome
[*]Pictures:
ocrejects
Orange County, CA
[*]JL Model: JLUR
[*]Wheel: gfx tr 10
[*]Offset: +12
[*]Pictures:
Jeep Wrangler JL JL Offset & Backspacing Finally Answered! 8F448221-E0B7-4329-BE86-AA553B8827B1
Who makes your back bumper?
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
EAG from amazon but I think it’s discontinued. Wanted a full wrap around which was kind of hard to find. I have eag front and rear bumper along with the sliders. Been real happy with them for the price. About $800 for all 3.
