JL Mopar front facing camera available?
Warz2k4
RIC
New York
n/a
Does this part exist and would it even be possible to install it without a bunch of splicing?
MARSHMELLA
Kirt
FL
2021 JLUR
Military
They are available from factory starting with the 2021 JLs. I have it on mine.
Warz2k4
RIC
New York
n/a
Yeah, but is it possible to buy it after the fact?
Warz2k4
RIC
New York
n/a
I dont think that's the same as the JL Mopar one from factory.(quality)
Bob Burd
Bob
San Jose, CA
www.snwburd.com
No, the Z Auto camera solution is elegant and simple, but it's low-res. I even switched out the camera twice. It's a limitation in the head unit.
Warz2k4
RIC
New York
n/a
I think the JL Mopar one is a better resolution. I'm guessing there's no way for me to get that correct?
aldo98229
Aldo
Bellingham, WA
Market Research
Someone is obsessed with Mopar.
DWS44
Rock Hill, SC (Charlotte, NC Area)
Toy Box: 2022 JLUR 392 + '17 C7 GS & '21 C8 Vettes
CAD/IT Manager (Civil/Airport Design)
Have to admit, I've also been curious if a retrofit is possible onto my 2018 since it became a factory option on newer ones, but haven't looked into it in a while.
aldo98229
Aldo
Bellingham, WA
Market Research
FCA never does “retrofit” easy.
Wbino
NJ
Here it is on my Wrangler.
Heads up...You get the wider spaced grill mesh to fit the camera I ASSume.
OMTBiker
Derek
Ohio
2021 JLU 80th Snazzberry
Information Technology
The front camera option utilizes the Gladiator grille inserts, almost positive the grilles are the same. Cost savings.
OMTBiker
Derek
Ohio
To the OP, my understanding is that the harness ties into several areas, the connection on the head unit is different, rear camera connection/harness is different, software programming, etc. and would not be feasible to retrofit. I have not and have no desire to tear mine down to find out for sure. The dealership parts department should be able to identify the different parts and part numbers between one without the camera and one with the camera if they had VINs for each.
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
It was done on gladiator forum. Very costly and very complicated. You'll need to replace your rear camera too as it is different between vehicles with and without front camera.
