Dan250378
- Daniel
- Oct 19, 2017
- Bremen, Germany
- BMW 530d
same here750kg max unbraked in aus
No it’s not, diesel starts with more energy in the fuel, before even using the more efficient combustion method, so even when not stressed it will get significantly better fuel economy when just lumbering along off boost. City numbers are not Overlanding numbers, and if you’d ever done it you’d know that. 80-100 miles of additonal range from 20gallons is quite easy to achieve. And calling it an illegal emissions system is just being obtuse.And no diesel JLU will get 100 miles of extra range overloading. Diesel fuel economy is only significantly better on constant load - e.g. highway, pulling a trailer.
Perhaps it has more to do with the strength capacity of the Wrangler towing hitch and/or that section of the frame/chassis. The Wrangler is not specifically built for towing but the JT on the other hand...Proves that the engine has nothing to do with the towing capacity on the JLU.
Towing vehicles have a more rigid chassis/frame and stiffer suspension. Those things work against a vehicle designed like a Jeep for more articulation and flex. Ram Power Wagon is a good example. It's a 2500 HD truck but doesnt have the towing/hauling abilities of a true Ram HD 2500 because of its suspension design.Perhaps it has more to do with the strength capacity of the Wrangler towing hitch and/or that section of the frame/chassis. The Wrangler is not specifically built for towing but the JT on the other hand...
I also find it amusing how people complain about the Wrangler's tow ratings. If you frequently find yourself needing to tow over 3500lbs should you really get a Wrangler? Sure having the ability to pull more is nice but how often do you need to tow? If often then perhaps you should get a truck....JT! But there will be those that will complain about the JT's tow rating too...so...
Ed ZacharyOffroad suspension that articulates well is not going to tow well, it will rock and weave all over the road towing a heavy load.
Nice theory, but I don't see how it explains why a North American Grand Cherokee or Pathfinder can tow 6,500 lbs, yet the Wrangler can only do 3,500.Found the article. It's on the internet so it must be true:
https://oppositelock.kinja.com/tow-me-down-1609112611/1609771499
Physics are the same, but did you read the article about how they LOAD the trailer? Of course the article wont say why a pathfinder can tow more than a jeep. They arent pitting different vehicles against each other. What they are saying is that based upon how much tongue load you put on a tow vehicle (percentage of trailer) will affect the handling (sway) of the trailer. Speed then becomes a huge factor in controlling the sway. in this article, the Wrangler would have a higher tow rating in Europe than the US, but so would the Cherokee because the way we load our trailers here in the US is different than how they load them in the UK.Nice theory, but I don't see how it explains why a North American Grand Cherokee or Pathfinder can tow 6,500 lbs, yet the Wrangler can only do 3,500.
Also, Europeans drive faster.
I don't see how the laws of physics are different in Europe or Australia.
