JL/JLU/JT Seat Slammers - Big and Tall Front Seat Drop (Desert Does It)
Steel vs 7075 Aluminum
  • Total voters
    85
  • Poll closed .
miweber929
Michael
Woodbury, MN
‘21 JLU Sport S, ‘16 Silverado
ok interesting and good to know. is that time actually installing the seat? I have a shop area to do the cutting, but lets say without painting, actual time on my needs installing the seat and bolting down?
Cheers!
It’s 4 bolts and an electrical connector so it depends on your tool setup and how handy you are. I’ve been playing around with the different seat jackers and spacing washers between my driver and passenger seats, as well as installing lumber in the passenger seat so I’ve had them loose and out a bunch over the last few weeks. First time was maybe 20 minutes to loosen, mount the jackers and tighten back down using a manual socket wrench and I’ve now gotten it to maybe 2 minutes to completely loose and another 3 to torque them down using my cordless impact.
Trick is to bring the seat all the way forward, loosen the rear 2 bolts, then move it all the way back to get to the front 2. My seats had 2 connectors underneath, one for airbag and I think the other was for seat heaters. I carefully tipped the seat to the side and it pulled right out.
F800
Canada
2020 JLU
Any tool recommendations?
I will buy an angle grinder to do the cuts
and Will a standard torque wrench
thanks for that detailed reply. That helps a lot
miweber929
Michael
Woodbury, MN
T50 Torx, standard torque wrench that will do 35 ft/lbs and a long extension makes it easy to get the inside front bolts out.
MonLee
Stan
NJ
2021 2 Door Sport S
Cheers!
That Time was start to finish. From starting to haul things outside, to walking inside with the last of my equipment. I didn't time individual sections of the install.
But I'd say that actually installing the seat wasn't super easy, I definitely struggled with getting it lined up properly I'd say that probably took over an hour.
DesertDoesIt
DesertDoesIt
Rock Sponsor (Level 1)
Las Vegas, NV
2018 RAM PW
Desert Does It BFCM sale is 15% Off - November 22nd-30th
BFCM2021
Free Shipping as usual
Valid on purchases made Today through November 30th.
2tall4red
Patrick
Brentwood, NH
2021 Jeep Grand Cherokee, 2021 JLUR 4xe soon!
Account Manager
Just finished my install. 3 hrs total 1st to last bolt. Unreal the difference these make. Like a new Jeep. I’m 6’5” and 330 lbs. my knee was against the dash now I have 5-6” space. The seat feels more bucketed now due to the increased rake. Like others commented now you feel like your in your Jeep and not on top of it. I went full slam 2” drop and it was best for me.
Make sure when you cut the back posts off to check the slammers for secure/flat fit. I needed to grind a bit more off to make them fit perfectly. Also recommend loose installation of the back slammers before you put the seat back in. Just be careful when resetting it you don’t scrape the interior up.
If your considering seat extenders check these out first. Glad I went this direction and now don’t need any extenders. Plus my wife is 5’ 2” so these allow full factory movement and she can still reach the pedals etc.
DDI scores with these. Thanks for the engineering VERY VERY happy customer!
YJGUY
Calgary Alberta
2020 JLU Rubicon, 2018 F150, 2018 V-Strom 650
Finally got around to installing mine today. Wow, what a difference!! Sitting in the Jeep instead of on top of it is the perfect description. I actually have thigh support now too. I feel like I'm taco'd into my seat. Its incredible how much more I can see out of the windshield, I can see traffic lights and the sky now! LOL. For reference, I'm 6'6" 425, so a pretty big guy. If I lose some padding off my big butt it will only get better.
I had been running the big boy brackets from Misch 4x4 but no longer need them with the seat slammers.
As for my install experience, it went well. Took me 3 hours as well. I could do it much faster next time. If anyone is local I can lend a hand and we could knock it out in 2 hours easily.
Other observations:
- It was only 10c (50f) here today so I used a heat gun to speed up the paint drying process. Watch you don't burn your seats if you do this. It singed my moving blanket I had in place.
- Take the head rest off your seat, makes it much easier to get in/out.
- Cover your door sill with a blanket or something so you don't scratch it.
- If you don't install the rear slammer parts before you put the seat on the Jeep you can easily do it by flipping the seat forward against the steering wheel to get better access. Way easier that trying to do it while its sitting on the floor.
- Don't forget to use locktite! I didn't when I installed my Misch 4x4 brackets and all the bolts were loose.
- Make sure you cover your seat with a moving blanket or similar when cutting/drilling. You'll have shavings everywhere and they are a pain to pick out of the fabric otherwise.
- I did one side with a sawzall and the other with a grinder. Same result either way but the grinder was a bit faster. Just make sure your seat is covered so you don't burn holes in it. My nylon track pants didn't fair too well. Doh!
Huge thanks DDI for making these, it has transformed the Jeep into something I'm actually happy to drive. :like:
If you are on the fence about getting these, don't wait, just do it. You won't regret it. If you are nervous about doing it or don't have the tools, Join a local club, I'm sure someone in your area would be happy to help you out.
F800
Canada
2020 JLU
Other observations:
great notes about the install. Thanks for sharing. Hopefully I’ll have mine in a week or so.
DesertDoesIt
DesertDoesIt
Las Vegas, NV
2018 RAM PW
Thank you @2tall4red and @YJGUY, I really appreciate the reviews and feedback. Happy to hear y'all finally fit IN your Jeeps.
Just a heads up, one more day of 15% off for Black Friday/Cyber Monday.
Desert Does It
Allmoparparts.com
