POL
- Adrien
- Sep 19, 2018
- French Alps
- JLU Rubicon 2.0T
It‘s a JKS JSPEC 2.5“ with Fox shocks. 2“ spacer should be possible but at full flex it might causes issues at the front bumper. You will need at least 8“ wide rims to get it street legal. I have the Mopar 17x8.5 Performance wheels.@hd.flstf this is exactly what I was looking for !!!!
What is your lift ?
Do you think that with 2" spacer front, and 1.5" spacer rear, I won't rub, considering the same tires as yours ?
Have you done the speedo calibration ?
This may help...I have jlur axles(1.5" wider) and had 315/70/17 ko2's on stock 17"×7.5" wheels with 2.5" lift and took this pic with sport fenders that are almost 1" narrower than rubi fenders. They poked beyond the sport fenders about 1" and tucked when flexing. I swapped to rubi fenders and tires were right in line with rubi fenders.Here is my JLUR 2.0T.
Teraflex leveling 1" front, 0.5" rear.
FOX IFP 2.0 Shocks
285/70 R17 Toyo GSI-5 (Snow tires)
I have 5 BF KO2 285/70R17 unmounted but I can't decide between it and a set of 315/70R17 KO2 with the 1.5" Teraflex lift kit...
Also waiting for the AEV front + rear bumpers, and 5 Savegre2 wheels for the summer tires.
Sorry, but this is not the case.It has everything that Sahara axle has. There is no reason to produce 2 types of rubi axles which differs only in lenght and ending, much easier is to put other existing axle and rename it.
They are D44 (M210) axles with CV joints rather than u-joints. Otherwise select-trac would not be possible. This subject has been beaten to death several times already.And second question: is it closer to us rubicon or closer to sahara axle
If it is a M210 it is a M210, no ?They are D44 (M210) axles with CV joints rather than u-joints. Otherwise select-trac would not be possible. This subject has been beaten to death several times already.
Why do you say they are using Sahara axles? Just because they have CV joints?Why would they be using a Sahara axle
Awesome. Thanks.For info, with 285/70R17 with stock Rubicon wheels, I still have 4cm of clearance:
Ok... i’m thinking about this sized tyre. Do they fit with the low level fender flares ok or did you swap to the higher ones?If it is a M210 it is a M210, no ?
Ok for the U-joint that is not mounted on, but the Rubicon axle is the only one that can receive the select trac and other specs of the rubicon... Why would they be using a Sahara axle ?
