JL Fuel Door Install / Video
obwahn
Inland Empire
www.youtube.com
Retired puter dork
@stuckinohio
Well, no way with the tether that is on there that you can hang over the door as you mention.
You could pretty easily alter / change the tether so you could do this.
Also, you could perhaps come up with a hook of sorts you could install in the cavity where the cap resides.
Another option... you could remove the tether altogether.. not recommending this but it is an alternative.
Mine can hang over the door. Unless the aftermarket setup is different, but it is Mopar. Since the cap is plastic is there any real problem with it hanging against the body?
stuckinohio
Lewis
Columbus Ohio
2018 Wrangler Sport S 4 Door
I don't like the idea of anything contacting the paint if it doesn't have to! Even though it's plastic it'll still scratch or wear down the paint at some point I would assume.
I guess it's as Jeep thing? Not for me if I don't have to.
stuckinohio
Lewis
Columbus Ohio
obwahn
Inland Empire
www.youtube.com
Retired puter dork
Understood.
Rhinebeck01
Multiple places..
Where did you find the little black hook?
I buy them by the bag. $2.97 for a bag of 25 at amazon.com
https://www.amazon.com/gp/product/B005MN2QHK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
After snip:
Took a small scissor and easily snipped part of the black plastic clip off (see pic) and then cut a small V in the plastic where the tether will lie, so it captures the tether better. Did easily with the same scissor.
I removed the cheapie double-sided tape that comes with the clip and replaced that tape with a piece of Command Strip. Command Strip (double sided) really holds. I did hit the white edges of the Command Strip with a black sharpie, just to assure I would see no white edges after install of the clip.
I figured out where I wanted it on the fuel door and made sure the door would still close fully, then applied.
Little project took all of what 12 minutes to do.
Went and purchased gasoline today. The little hook works great! Just have to maneuver the rubber splash guard on the gas hose as I inserted the nozzle... maneuvered so it slid past the hanging gas cap. Was easy to do.
Can say, I too do not like laying the gas cap against my paint.... so this clip is something I will keep using.
By the wa,y the little black clips come in real handy. The double sided tape is decent on them but for this application I decided Command Strip was best used. Command Strips deal with water, dampness, roughness well.
Kenny
Ken
Utah
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
After snip:
Thanks
klhjeep2018
Kevin
Harpers Ferry, WV
2018 Rubicon JL
Sales manager
I put on the Mopar locking gas cap. The plastic tether that came on it broke in minutes. A piece on crap. The cap is good. So I used the tether off of the factor cap. Just drilled a hole in the side. Again I just lay it over the lid.
Rhinebeck01
Multiple places..
@klhjeep2018
Yup, I can do with stock tether it turns out.. BUT, I do not want the cap against the paint.
LouNYC
Lou
New Jersey
www.instagram.com
2018 Jeep JL Sahara
I just purchased the Mopar Gas Door as well. Very excited about putting this on. The description said it was chrome but it is more stainless steel.
My vehicle doesn't arrive for another month, but I have started to purchase a few items.
P.S. Will be installed on a Granite Sahara. Purchased on eBay for $139 including free shipping.
stuckinohio
Lewis
Columbus Ohio
Thanks to @Rhinebeck01 for this idea. Made my own out of some heat formable black plastic I had around the garage for other uses. I'm gonna get gas with it and see how I like the placement then move it if need be or get/make a longer tether.
This fuel door was super easy to install. This Jeep is sorta like a toy truck or kit vehicle. It's so easy to change stuff out so far!
Kenny
Ken
Utah
Village Idiot
I tried to install a new gas cap today but couldn't get the original off. It has two clamps that hard to get to. Any suggestions?
Thanks.
I just pulled hard and it finally popped out
Rhinebeck01
Multiple places..
@stuckinohio
Just came up with a small, black plastic, stick on, sturdy, hook to hold the gas cap when it is removed. It looks aok.
Will let you know after a couple of stops at the gas station if it does the job aok..
On edit 10/20:
Well, it has been about two YEARS since I placed the plastic gas cap hook on my JL's fuel door.
Just wanted to give an update. Anyway, it has worked out really well! I have grown so used to it.
It is second nature for me now, to hang the gas cap on the hook, and then when I bring the gas pump nozzle toward the fuel door, I take my free hand and fold back, the rubber splash guard on the fuel handle so I can easily insert the nozzle without touching the fuel cap that is hanging on the fuel door.
In closing, tried and tested... if you don't like having the fuel cap/gas drips from same lying against your JL's paint, this mod works to prevent same. And a mod that cost less then 16 cents...
Jeep Wrangler JL JL Fuel Door Install / Video 01
