JL Dana 30 & Dana 35 - how strong are they?
Punk'n2doorsport
Willian
Nova scotia
2018 JL wrangler sport, 6spd manual, 3.6L
Trucker
I saw someone on here with a eaton trutrac in the front dana 30.
arb uses the same front diff Locker for the JK as the JL- RD100
so assuming the eaton trutrac would fit as well. Id like to throw in a limited also
Im planning on 4.56, 33s and a small 2" lift, with LSD front and rear would be deadly in a light little rig
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
yes sir, my jeep is 4320lbs.
nice and light. Its on 35s and 4.56 gears
2” mopar springs and a Frankenstein lift
Although the rear lsd is worn out already.
Next will be a rear locker and maybe a front limited slip like you said but not sure i want to invest too much into the dana30
Punk'n2doorsport
Willian
Nova scotia
Trucker
So I found out that the front Dana 30 is the same as the JK Dana 30 as far as the gears go so you can put a truetrac in the front and the only reason that I'm going to build my Dana 30 is because I'm staying light I'm not going to go with 35 I'm not going to go super heavy rock crawling and my little lift will be Frankenstein as well KINGS 2.5 with piggy back reservoir shocks are on the wish list as well as the Evo Overlander enforcer kit
With a two-door sport like mine I'll get at least three inches of lift
Shellbird01
Bob
Ontario Canada
2018 Wrangler JL Shara Unlimited
How did you know when you’re lsd quit? I have 80 Kms on mine, I put the jack under the pumpkin and the wheels spun opposite but when I spun on the grass it appears to lock?
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
if they spin opposite that is good.
When i spin driver side the passenger side doesnt move, when i spin the passenger side, the driver moves a little bit in the opposite.
rear locker is next on my list anyway
Shellbird01
Bob
Ontario Canada
Thanks. Which locker did you decide? Are you going ahead with the lsd in the front? I’m in Ontario and I‘m interested to know how the lsd in the front handles in the snow.
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
arb is the only option at this point for rear so.
No, probably wont invest money into the dana30. Better to put into a 44 so I can move to 37s
Shellbird01
Bob
Ontario Canada
I installed a Teraflex 2.5” lift and Rubi take off 33‘s and don’t plan on going bigger. I’m considering Truetracs on d30 d44 once the mopar lsd dies. Then Rubi d44 take offs once the USA border reopens or we get some inventory in Canada. I have no interest in the costs with regearing.
I suspect the d30 d44 with TT are fine for what wheeling I do, trails, some mud, downed trees and zero rock crawling.
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
buy once, cry once. Dont invest into the stock axles if your plan is rubi take offs. Just do them and they come with gearing to run 35s
forsure, ive abused the 30/44 on 35s for two years without issue.
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
I thought the gears were different sizes, the m186 being a smidge larger than the jk dana 30
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
I believe this is true, but the carrier will still works.
ie: the arb rd100 air locker is used for jk dana 30 and also works for the JL dana30 or m186
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
Ah that’s interesting, didnt know the carriers work with the newer m186s.
Odyssey USA
Daniel
www.youtube.com
Sahara
I opted for the new rear Ox locker for the M200. They also charge the same price for the differential to move up from 29 spline to 32 spline. You only need axles for a standard width M220 (non-Rubicon).
Shellbird01
Bob
Ontario Canada
Electric or cable actuated?
