Jl audio stealthbox released
Tpham
Tom
ohio
2018 jeep wrangler sport s
shatty
Billy
Brooklyn, NY
2016 Lexus NX 250, 2016 Corvette ZO6/ZO7
I have the Alpine upgrade in my Sahara. Installation of the Stealthbox on the passenger side requires the stock parts from a JL that doesnt have the Alpine upgrade. Does anyone know the part numbers from Jeep for that parts that are needed to do the install? Im getting drivers and passenger side boxes.
Jerseyed1975
Ed
NJ/NYC
2017 Raptor, 2018 JLU Rubicon
Careful using these with the soft top. You won't be able to remove it from the rail into a full open You are better off looking for a different option if you take the top down all the way
algoo31
Albert
WA
2018 JLU Sport
Doesnt look like they will fit for us that have a sport with no OEM sub.
Looks like an OEM replacement, unless I read that wrong.
Tpham
Tpham
Tom
ohio
It is for us without the OEM Alpine sub. If you have the Alpine sub you will need the panel like we have on the passenger side to be able to install it.
WhyUMad
Ryan
New Orleans, LA
Mechanical Engineer
Do you just need the panel or do you need new carpeting too because the alpine sub box takes up some floor real estate as well (I assume it does at least)?
Tpham
Tpham
Tom
ohio
im not sure. i dont want to give you an answer i dont know. lol
WhyUMad
Ryan
New Orleans, LA
Mechanical Engineer
Lol, thanks for the honesty. All JL mentions is the panel, but I think the carpet is dif too.
RubenZ
Ruben
Deep South Texas
myjlproject.com
2020 Toyota Tacoma TRD Off-Road, 18’ Toyota 4Runner
Check LiteBrite's video on JL Audio Stealth box and Audio upgrade
TimAugie
South FL
2018 Wrangler JL Sport S
Question about this as I didn’t fully understand from the JL Audio website. When you refer to taking it all the way down, you’re just talking about folding it all of the way back into the trunk? I often do that so I wanted to get clarification on that before I consider the stealth box.
Originalp123
Kai
Salem, OR
2019 Jeep Wrangler Unlimited Sport S
Hey man I was confused and looked into a video about the soft tops and found out my answer. This will work with both the sun rider position and the top fully down but you can’t detach the top from the rails and lay them in the trunk. So the two positions that you mainly use are good to go for this stealthbox!
Mattk11
Nebraska
'20 JLU Rubicon
I think it pretty ironic they call them stealth boxes when you can see them in plain sight. Nothing hidden about it. I fabricated my own "stealth boxes" that are actually hidden under both of the front seats that have the same internal volume, can run a 10" shallow woofer and handle double the power for less money, just my time (although your local shop may charge a bit more). You can see the side of the enclosure with the doors off, but no one would know what it is.
Winjet
