JL 33” tires small lift - Pictures Please!
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
The dealer tried to make me pay for a fad actuator, but the service manager approved when I argued we didn’t touch it. But they said the power train warranty is gonzo
A lift has nothing to do with the power train. Really what you have is the equivalent of a Moab.
They can say all kinds of things, and refuse to cover stuff, but the law says they have to show that the modifications could reasonably have caused the problem.
The Jeep looks great.
brain
brian
Milton, Georgia
www.unsinkablebriancork.com
2020 Wrangler JT (Gladiator) Mojave | Gobi
Business and Executive Coach
If i understand you, you can look at photos of the 2020 jl rubicon recon which comes stock with ½ “ lift and 33’s.
Rubicons are higher off the lot than Saharas and Sports because they have more substantial suspension. The Rubicon high profile fenders also help with additional clearance. And, yes... They do come with 33” tires over 17” wheels, whereas the other trim packages often have 31” tires over 16” wheels.
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
No 16 inch wheels on the JL. Can’t clear the brakes.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I do stand corrected. However, Rubicons do come higher with a different suspension.
You are giving out some misinformation however. Rubicons come with 285/70/17 KO2s on 17 wheels and they measure out to 32.8” nominal.
Saharas come with 255/70/18 GY Adventure ATs on 18 wheels and measure out to 32.1” nominal. Sport comes with variants of the 245/75/17 HT on 17 wheels which measures out to 31.5” nominal.
Rubicon suspensions are about 0.75” higher than Sahara and around 1”-1.25” higher than Sport/Sport S. [Ground clearance: Rubicon(11.8”) Sahara (11”), Sport (10.8”)]
Both Rubicon and Sahara has bigger rotors so the smallest wheel you can fit over it is 17”. Sport you can fit a 16” wheel due to their smaller rotors.
1Greywolf
Jose
Alhambra Ca
2020 jlu rubicon, 2012 jeek jk
Does anybody know what the lug nut torque specs are for a vision nemesis wheel? I plan to mount a 38" tire on a 17x9 wheel on a 2020 jlu. I will be using spline lug nuts.
Thanks,
Jose
REAWS6
Michigan
2022 Gobi Rubicon 4xe
Thanks,
Jose
130 was the number I kept finding when I pit my wheels and tires on. Seems that number is what is recommended for any aftermarket wheel.
1Greywolf
Jose
Alhambra Ca
I agree with you, it is a number that kept showing up. Thank You REAWS6.
brain
brian
Milton, Georgia
Woodynj
Justin
NJ
2018 JL Sahara
33"" with 1.5" offset and rubbing in back. Need a lift or no offset.
love the stance of your jeep. Those are 33's? They look bigger than that. Can you share the specifcs on wheel/tire? I am back and forth on going 33 or 35s and keeping the lift to a minimum (if not zero) on my sahara. Would love other pics too if you have it. Thanks in Advance!
Reabob
Montreal, QC / Champlain, NY
Wrangler JL Sahara unlimited 2018
Hi, yes they are 33".
Milestar Patagonia M/T.
Wheels are Mickey Thompson M/T metal with about 1.5" offset.
So the fact that fenders on JL are (sorry my english, not sure who to say this) bent down alot, tires seems larger with this offset.
I went on trails not lifted and i am rubbing alot on rear fenders... One of them popped out!
Woodynj
Justin
NJ
2018 JL Sahara
Jeep Wrangler JL JL 33” tires small lift - Pictures Please! IMG_20200319_184118547_HDR
Seeing those pics makes me just want to go with 33 instead and skip the 35s and small lift.
Reabob
Also depends in which brand. Patagonia 33, are about 32.3" for real.
BFGoodrich 33 are about 31.9".
Also makes a difference.
If you have Rubicon, you already have more clearance. I am thinking of changing to Rubicon fenders before a lift. Not sure yet!
