JL 3.6L - Oil Dipstick Issue
neil
neil
Dallas, TX
20 JLUR, 21 JLUR and others
post a photo or two of your dipstick. No kink. Curious if they were that sloppy.
Dan M.
Albany NY
2020 sport (2 door)
No I hadn't checked it myself prior to this but like I mentioned, the oil had been changed 3 different times at 2 dealerships and they didn't mention it.
From the feedback received so far it looks like the wrong dipstick was installed from the factory. I'll order a replacement.
You are either much braver or much more trusting than I am.
WagzDad
Carroll
South Louisiana
After any kind of service anywhere I open the hood and look around for stuff open undone or left behind. I have been rewarded for my efforts more than a few times.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
The length of the oil indicator is a function of the length of the oil indicator adapter tube. Sometimes there are production changes due to a change in suppliers. Bottom line, give the dealer your VIN so you get the right indicator for your specific 2019 3.6L.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
My dipstick shows a quart low after adding in 5 qts since I got the jeep. I didn't even know there were two different dip sticks. 3.6L
Bearded_Dragon
FL
2018 Mojito! Rubicon
I have to spin mine before removing the dip stick to get an accurate measurement. Maybe try that?
Ilya
Ilya
Ontario Canada
Jeep 2019 sport 2 door 6MT
Need help... Does anybody know how much oil is between min and max on dipstick?
Jimac
Jim
Kingston, OK
2018 JL Rubicon
Yes I have found stuff open and undone, I have also added to my toolbox with assortment of wrenches and shop rags.
blnewt
New Mexico
Just ask @cosine he knows!
Yep, for that new cast-iron steering box TSB they left the bolts under-torqued, re-used a bolt that specifically calls for a new bolt to be used (also under-torqued) left my steering fluid reservoir cap laying on the side of the motor too!
YAY!
OldGuyNewJeep
Don
CT
Don’t overthink it. Drain oil and put 5qts back in. No need to look at dipstick.
OldGuyNewJeep
Don
CT
Rhinebeck01
Multiple places..
thats what I have been doing but maybe I should be checking the dipstick also :o
@zeebo56
The JL/JT with the 3.6L, requires 5 quarts of oil.... You put in 5 quarts. 5 qts. is 5 qts.... No reason at all to bother checking the dipstick when you just poured in 5 qts. of oil... when you do the oil change.
From FCA press release when they introduced the 2nd Gen Pentastar...
"Windage-tray weight was slashed by 19 percent and front-cover weight was cut by 5 percent. *The oil pan was redesigned from a two-piece to a single-piece pan and the sump was reduced from a 6-quart fill to a 5-quart fill *– resulting in an overall 5-pound weight savings compared with the previous generation Pentastar V-6 engine."
Rhinebeck01
Multiple places..
Not in my opinion.
@OldGuyNewJeep
Yup, but watch some knucklehead here, come up with a reason / post why, in his opinion... you would need to check the dipstick right after you pour in 5 qts. of oil into the 3.6 L, JL that takes 5 quarts of oil.
DanW
Indiana
This thread has developed into a dipstick measuring contest.
LOL, I just could not resist the setup for that!
OP, did you get the new one? I'd take that right to the service manager of the dealer. That should be on them. I'll bet they get a few bucks for a new dipstick. Make them cover that. Their mistake. IF they balk, have them grab one out of another 3.6 and compare them right there. (Again, a dipstick measuring contest!) :LOL:
Otherwise you could post the pics here side by side and bring it to the attention of @JeepCares if the dealer doesn't cover it.
