Rodeoflyer
- Bert
- Dec 16, 2019
- Conifer, Colorado
- 2020 Jeep JLUR; 2016 Ram Powerwagon
- Vehicle Showcase
- 1
Absolutely.. a manual transmission saves wear on EVERY other part of the drivetrain. There is no doubt about that. It saves your brakes, it saves your motor, saves your gears and lockers, it doesn't need a torque converter, it's the THE simplest of drivetrain connectivity known to man. I rarely even have to use my brakes.. IF you know how to use a proper manual trans.Congrats on passing on the skill to the next generation! Drivers ED cars should still be manual.
This monstrosity exists because of CAFE fuel economy standards. In order to squeak out a higher number, manufacturers went to auto start-stop systems. It takes fuel to start and engine, but the lower your rotational mass, the less fuel it requires, plus, it's easier on the starter motor for additional reliability. To lower the rotational mass, they reduced the size and weight of the flywheel.
That had the negative affect of reducing the torque capability of the clutch assembly, so they went with a twin-disc design to double the area of friction surfaces to regain that clamp load. On the flywheel side, the low-mass flywheel was insufficient to absorb the nvh of the motor so the dual-mass design effectively canceled unwanted vibration at a lower overall mass.
All of this is terrific for a small car or SUV. It's terrible for a heavy SUV, especially one that's going to see larger heavier tires. Plus, once we install our Tazers and deactivate the auto-start-stop, the benefit of this clutch system is completely neutralized.
The CF is a basic design that's worked well since the beginning of motorized times. There weren't any reliability issues with the clutches themselves, it was the stock hydraulics that were out-matched. That has been improved upon. I don't know about an install video but there are a few step-by-step threads on this forum covering it.
CAFE and profit over reliability is the devil IMO
And brake dust, the environmental impact is greatly reduced with a manual trans.
It's about PROFIT not environmental issue
