Jk lugs wouldn't fit JL
Jlb1177
JLU Rubicon
So I traded in my 14 Sahara for a JLUR and my DC matrix wheels wouldn't fit. Said the lugs are to small or whatever. Has anyone run into a similar situation ? And how or what do I do to fit the wheels?
Jeepsterfreak
Honda, Future JLU
This is correct. The lug pattern is the same but the JL lugs are slightly larger diameter. The JL lugs are 14mm vs 1/2. If the wheels won’t physically fit because the lug holes are too small, I suppose the holes could be drilled or honed to fit 14mm lugs.
Jlb1177
Jlb1177
JLU Rubicon
But theoretically wouldn't the jlur lugs fit the new wheels? Not sure why they wouldn't fit...
Jeepsterfreak
Honda, Future JLU
The only reason they would not fit is because the wheels from your JK have holes designed for 1/2” lugs. The JL has 14mm lugs which are very slightly larger than 1/2”. It’s possible the holes in your DC wheels are too small for 14mm lugs so they would need to be enlarged.
Another reason might be the hub clearance but I don’t think that changed.
Another reason would be if the wheel does not clear the brakes. This might only be a problem with wheels 16” or smaller.
Jlb1177
Jlb1177
JLU Rubicon
Thanks a lot for the insight. Now I know what to ask.
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
Lug nuts can' be switched from jk to JL. Wheel are supposed to work from jk to JL. They sell the same wheels for a jk and jl.
  • Like
Reactions: J0E
