JK Lightbar 123220RR on a JL
americonium
Abe
NY
2018 JLUR Black
Engineering Technician
I was gifted the aforementioned lightbar and three led off road lights by my wife. It wasn't until I opened the package and started to try the install that I figured out that this is from the JK. I am pretty sure I can modify this to work, but has anyone else gone through the process? I figure that since the JK bumpers fit the JLs, I can probably get this lightbar to fit as well. Thanks in advance for any advice...
cosine
NY
2019 Wrangler Sport jl
Gone Postal
i looked on the fitment page and did not see anything listed for the jl model. also the jl frame is different from the jk frame.
americonium
americonium
Abe
NY
2018 JLUR Black
Turns out, with enough swearing, and a drill, you can do anything you want.
Jeep Wrangler JL JK Lightbar 123220RR on a JL PXL_20201229_195231174
cosine
NY
Gone Postal
looks good. nice and clean. at first i didnt think it would fit.
so what did you end up in doing to make it fit.
americonium
americonium
Abe
NY
2018 JLUR Black
I had to flip the passenger side to driver and vice versa, I had to trim the top corner to fit around a bracket on the frame rails,
Jeep Wrangler JL JK Lightbar 123220RR on a JL PXL_20201229_143600648
I had to drill a new hole in the bottom of the plates,
Jeep Wrangler JL JK Lightbar 123220RR on a JL PXL_20201229_144541526
I drilled a bolt hole in the actual frame,
Jeep Wrangler JL JK Lightbar 123220RR on a JL PXL_20201229_145427962
I punched two holes in the plastic panel that fills the gap between the bumper and the grille, and I had to trim 1/4 of an inch of the back of the front bumper where it meets the bar.
Sorry, I quit taking pictures after the frame drilling. I painted all of my holes with flat black rust-oleum, drilled three wiring holes in the light bar
Jeep Wrangler JL JK Lightbar 123220RR on a JL PXL_20201229_173036352
, and spent the next day wiring the whole thing up. The lights have three settings. DRL, those come on when the lights come on, low, those are activated by a switch in the dash, and high, which are activated by the high beams, but only when the low beams are activated. I plan on going behind the grocery store at night to see how bright they are, but I've been too busy since I installed them.
