Go to the contact form and you can select Softtop in the drop down. I believe he will then send you a quote. Looks like he’s doing a $50 off currently on all tops.
I just installed mine and it looks good. Such an easy install. The only problem is that I don’t have access to the underside of the bolts to put a nut or something to keep it secure. It’s covered by plastic coverings.
I was just looking into getting one of these, I hope y'all can answer some questions about it!
1. Any changes in opinion after a year/two years of ownership?
2. Is the tailgate half required to secure the rear-seat half?
3. If not required, will the soft top lock be able to open fully and lock if the tailgate half is uninstalled?
4. And if it does lock, how much of the cargo area is exposed?
I primarily run with the soft top in 'Safari mode', but if I can simply uninstall the tailgate half to put the top down, it would be ideal.
