path0s
- Mike
- Jan 4, 2022
- Goose Creek, SC
- 2021 JLUR XR
Seems the wider axles are doing wonders on JLs in comparison to JKs and running 37s.Minor trimming of the fender liner was sufficient to stuff them. You could probably use a heat gun in the rear to clearance but I caught them in a “whoops” section out in Moab and trimmed with a pocket knife. I also trimmed a tiny bit off the body panel seam in the rear as i was concerned about it potentially grabbing a tire at full stuff. Any rubbing would have happened regardless of wheel offset and axle width, and was due to up travel with larger tires and my not wanting to run any more bump stop than necessary. It could have been solved by running more bump stop with no trimming
