Jeep Wrangler Sport Upgrade - 265/70/17 or 285/70/17?
yell03
PA
2020 Jeep Wrangler JL Sport
I just bought a 2020 Jeep Wrangler Sport Black and Tan 2 door. I have previously owned a 2018 JLUR with 35x12.5s on it.
I want to upgrade my wheels and tires on the Sport, but I don't want to sacrifice Acceleration, Ride Quality, and Gas Mileage too much.
I have the 4 cylinder with automatic, 3.45 gearing.
It comes stock with 245/75/17s on 17x7.5 rims.
The tires weigh about 38lbs and the rims are approximately 22-25lbs I hear, so 60-63lbs total.
I found Fuel 17x8.5 rims that are 25lbs each with a -6mm offset./4.5 backspacing.
The big difference here will be the tires.
265/70/17s I can get the same brand Bridgestones that are on it = 40-43lbs
BFG KO2s I can get 265s at 44lbs or 285s at 51lbs
Then I found Toyo Open Countrys 265s at 47lbs or 285 at 48lbs.
Hours of research here, I do not want to make a mistake.
I want the best looking combination I can get, but I do not want rubbing.
Should I do the 265/70/17s, I gain 1 inch in width, but same height or the 285/70/17s and gain 2 inches width and 1 inch height, at the expense of an additional 5lbs over the 265s plus reduced gearing?
I am also thinking of going with Bronze Rims to complement the Tan top.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
I've been running 265/70/17 K02s for over 7k miles and haven't noticed a difference in performance/mpg. However, I have the 3.6 engine. This is my daily driver so I was concerned about impacting fuel expenses etc. There is no rubbing at all either.
Here's a picture on my JLU before I installed the rubicon suspension.
yell03
yell03
PA
Thanks...
I had the 3.6 in my Rubicon.
With the 265/70/17s, being the same height as my 245/75/17s, I knew that would be VERY close in all aspects.
My wife wants me to go with the 285s, she wants more stance.
Even with the 265s and -6mm offset, it would stance out nicely.
The pic below is the exact set-up my wife likes, 285/70/17 on 17x8.5 rim with -6mm offset. I would do All-Terrains instead of Mud-Terrains.
Gpdan
Abilene
2018 J L sport s punk n
I put 275/70 k o 2s on my 2018 sport. No pics right now but they look good.
The only information I can add to your decision basis is:
  • taller will slow the acceleration and increase fuel burn for acceleration, but may be a wash or even better MPG at constant highway speeds depending on rolling resistance.
  • wider increases rolling resistance and increases weight
  • increased tire/wheel weight increases unsprung weight, which deteriorates on-road ride quality
  • more aggressive tread increases rolling resistance which degrades MPG
One example is my GMC pickup. It got about 18 MPG on average with the way I drive, with the stock 32" tall 265 street tread tires. I put on some 33", 12.2" wide, hybrid (mud/AT) Cooper STMaxx tires and it dropped to 15 MPG average. That's a 17% reduction in fuel economy.
When I was driving 20,000 miles a year, 18 MPG is 1111 gallons or $3888 @ $3.50/gal. 15 MPG is 1333 gallons or $4665 @ $3.50/gal
AZ Hella
Sonoran Desert
JLUR
I have a manual transmission, rubicon suspension and 3.45 gears running 285 70 17 and it’s great.
cavguy
Arizona
2020 JLUR
JLUS 2.0L Auto transmission here:
I went with P rated 265/70R17 Falken Wildpeak AT3W's for my sport, they were very nice with the stock suspension, no speedo adjustment needed and MPG stayed approx. the same as with the stock tires.
However, since I lifted the Jeep 2.5" now they are too small (IMO)...
So, that said, you might want to think about if you will be installing a lift. If you will be installing a lift, then go with the 285/70R17's and get your speedo recalibrated. Look for Rubicon takeoffs, either the KO2's or Wildpeak's (I would avoid the E rated tires if I were you).
If off-road performance is a big consideration, not surprisingly, larger diameter is a big swinger in improving traction and steering per some tests Honda did many years ago. If you aren't doing any off-roading, stay small diameter for the mileage.
The Falken Wildpeak AT3W is a nice compromise tire for quiet on the street, while giving you some off-road capability (not mud). The AT3W has generally a less aggressive tread than the BFG K02, similar to the Toyo OC AT tire.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
I went with KO2s 285/70/17 on my 2018 2.0T Sahara. with my wheel and tire combination I ended up adding about 25 lbs per wheel (62-87).
When I first drove it, there was a noticeable difference, but I think that both the Jeep and I have learned to live with these tires, and acceleration/braking etc, are probably different now to when it was stock, but to be honest I couldn't tell you what stock was like any more!
I have lost a 1-2 mpg, not sure exactly how much, but there was a definite reduction 22ish to 20ish.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
I have a sport. Ran stock rubi tires/wheels for a year. Looked and ran great. Barely noticeable change in performance and mpg. Worth it for the looks alone.
yell03
yell03
PA
I thought about the 275s, right in the middle.
Right now I am getting 17.5mpg all city driving. My JL Rubicon before with the 35x12.5x17 was getting under 14 on the highway.
MPG is my least concern, but I still like not paying as much at the pump.
My biggest concern is driveability. It runs great with the little 245/75/17s, just looks small.
I am sure the manual tranny helps.
Do you have any pics with the 265s before the lift?
I am looking at C rated.
I had the KO2s on my Raptor, great tire. I was looking at KO2s, Toyo AT2s (my son says no), and the Falkens. Weight is the main reason I was looking at the Toyos. The Bridgestone ATs that come stock on the Sport are very light, but not made in 285/70.
I am trying not to add that much weight per wheel. I could live with 15lbs extra, but I'd rather not.
Most likely I will go for the lightest weight 285 on 17s I can find.
Stock 2018 SAHARA tires/wheels--
Added 285/75Rx16--no suspension changes-
No problemo-
JIMBO
Thanks!
yell03
yell03
PA
I don't have pics sorry..
Not a problem, I have seen quite a few with 265s. I think the 285s will probably look better, as long as I don't need a lift.
