Jeep Wrangler Sport Upgrade - 265/70/17 or 285/70/17?
Abdelxziz
Abdelaziz
SHJ
White sport Jeep JL
I've been running 265/70/17 K02s for over 7k miles and haven't noticed a difference in performance/mpg. However, I have the 3.6 engine. This is my daily driver so I was concerned about impacting fuel expenses etc. There is no rubbing at all either.
Here's a picture on my JLU before I installed the rubicon suspension.
Did you notice any differences in the speedometer speed?
Htfan
OC, CA
2018 JLU Sport S - 3.6L
Only sight difference in speedo. Maybe 1 or 2 mph off at highway speeds when compared to GPS.
CGRubicon
PA
2017 Jeep Grand Cherokee
Just bought a 2019 JL 2 Door Sport. Can I use stock Rubicon takeoffs (KO2’s or Falken’s) without any other modifications or speedo recalibrations needed?
yell03
yell03
PA
2020 Jeep Wrangler JL Sport
Yes, speedo will be slightly off, not worth doing the calibration. Shifting and drivability will not be affected at all.
CGRubicon
PA
Thank you
HighGs
Nick
Gardner
2018 Jeep JL Unlimited
I ended up with the 285/70/17s BFG KO2s C Load Rating.
MPG is actually the same.
Performance seems the same.
It is only a 3% difference in tire height, a little more than 1 inch taller, so not much of a difference.
The -6mm offset of the Fuel 17x8.5 rimsmakes it seem bigger than it is, has an aggressive stance.
No rubbing.
Sorry if I missed this, but did you install any kind of lift or just stick with the stock suspension?
yell03
yell03
PA
I left the suspension stock. No problems and running great almost a year later.
erickdiaz019
Erick
Minnesota
Jeep Wrangler JL
Do you have a picture of after you installed the rubicon suspension? I wanna see what 265/70/17 looks like with a takeoff Rubicon suspension.
Htfan
OC, CA
Here's a picture from a while ago shortly after Rubicon suspension installation
erickdiaz019
Erick
Minnesota
Jeep Wrangler JL
WOW that stance looks really cool! Do you happen to have a picture directly from the side? And are wheel spacers necessary to avoid rubbing?
Htfan
OC, CA
Thanks! I'll need to see if I have a direct side shot.
Wheel spacers are completely optional. No rubbing. However, I have 1.5" spacers to improve the stance.
erickdiaz019
Erick
Minnesota
Jeep Wrangler JL
Ok. And what pressure are you running these tires at?
Htfan
OC, CA
Htfan
OC, CA
Did you just arbitrarily pick that psi to run with?
No, I had some steering wander issues early on before a series of TSBs/updates and reduces psi at that time. Too high psi can also cause part of the problem. Working well overall and steering is solid now. No urgent reason for changing/increasing.
Superchips TrailDash 3
