Jeep Wrangler Sport Upgrade - 265/70/17 or 285/70/17?
agpthng
New Hampshire
2019 Jeep JLU
I upgraded mine to 285/70/17's Mickey Thompson MTZ BAJA P3's with Pro Comp rims. I lost a couple miles per gallon but am getting 18-20 currently. I don't notice a difference in it's acceleration at all, we did have to trim a little off of the bumper or the part that is under the bumper to stop it from rubbing with a hard turn, like in a parking lot.
yell03
yell03
PA
2020 Jeep Wrangler JL Sport
  • Thread starter
  • Thread Starter
  • #47
I hope I don't have to do any trimming. Everybody has said no rubbing, your tires might be a bit more aggressive than the KO2s.
If you can, can you get a close up of how much you had to trim off?
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #48
Actually, this will be helpful
Rafael004
rafael
miami
jiu wrangler sport
Engieneer
i put 285/75/17 and not lift , and haven't noticed a difference in performance
sport 3.6
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #50
1quick1
Moderator
Staff member
Moderator
2018 JLU
At one point I had stock Rubi wheels/tires 285/70/17's on my Sport.
No rubbing. Speedo was only off about 1-2 mph at 70mph. It did seem more hesitant to go into 8th but not impossible.
I then went 315/70/17 and a 2.5" spacer lift and that I had the dealer recalibrate the speedo as it was off like 7 mph at hwy speeds. Now it's perfect and will go into 8th if I'm flat at 65mph.
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #52
My Rubicon with 35s rarely went in to 8th, best I did on the highway was like 15mpg
KananagaS
Sho
Yokohama, Japan
2020 Jeep Wrangler Sahara
Engineer
Not sure if Sahara and Sport share the same suspension. Mine is the Japan version Sahara with the same/similar mud flaps at the front bumper. The rims are 17x8 ET10 with BFG KO2 285/70. No rubbing at all.
Even at light off-roaring, the rear clear the inner fender liners.
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #54
Sahara suspension is in the middle of Sport and Rubicon, but still should be close enough.
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #56
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #58
yell03
yell03
PA
  • Thread starter
  • Thread Starter
  • #59
They are on...
Melny67
Melvin
Staten island
Jeep jlu
I have 265/70/17 at3w on my sport s. If you are not planning on a lift I would go with that setup. Anything higher then 33 or higher look crammed in a JL sport in my opinion. Plus mpg hit and 8 gear struggles and not to mention your speedo will be off 3mph. Some people are fine with what I just said so it's up to you. But 265 and 285 don't seem much of a difference. The biggest difference for me was the price on tires I spent around $600ish on five tires if I went up a size it would costed me $350 more. At that point I rather just buy used OEM Rubicon tires and wheels.
