migyb
- Miguel
- Feb 10, 2020
- Vancouver, BC
- 2020 JLU Willys
Hi everyone,
(this will be quite a long post)
Thought I would make a post here before going to the dealership. Took my 3 little sisters out off-roading in a very muddy/watery area. Long story short, I try clipping an edge of a puddle with my driver side tire (because that is fun and it entertains my sisters (the youngest is 4yo). Right as I go over the puddle, land begins to collapse (maybe due to the weight of the Jeep?) and turned a fun off road trip to a nightmare. Water gushes in, driver side is tipped into the water while the passenger is still ok (water going in door seals). I get my sisters out (through passenger side windows)and made sure they were safe. My jeep however was partially submerged (driverside more than the passenger).
Jeep kept running as I was in the water but I feel like everything was shorting out. Lots of flashes on dash, error messages that I do not remember - ended up stalling while in the water. I hop out to comfort my sisters as this freaked them out.
My dad was in his rig but was quite a ways back from me. He ended up pulling me out, electricals were being wonky but I managed to get it back to park and attempted to start it. It started out fine and my dad noticed that water spewed out of the exhaust.
While cleaning up the tow strap we used to pull me out, the engine just stalled (after 5 mins or so of starting it). After this, it never started again and was stuck on ignition on/accessory on mode. We were rescued by 2 fellow jeepers who flat towed us from where we were to the main road (30 mins at least), from then on the jeep got towed back home. There was no way for me to turn off the ignition. It was stuck on ignition/accessory mode, no matter what I did to it. Normally I would just cycle through OFF/ACC/RUN, but it would not cycle.
I figured out how to cut the power to the jeep by removing both negative grounds of both batteries, (mainly the negative terminal of the aux battery). I had to put power back on as it was night time and needed as much visibility as possible. When I got home, my headlights were barely on, the battery has been depleting the entire day 7+ hours so I know for a fact it had little juice.
Main issue is we thought it was hydrolocked. Mind you, air filter was dry when I got home, plus that side of the vehicle was never submerged in water.
The next day I did an oil change, and oil was not milky and looked like what oil should look.
I took out spark plugs, they were bone dry.
I wanted to get starter to crank to see if any water shoots out of spark plug hole, but there was no way to get it to crank (no way that I know of). Remind you that the push button was not cycling through the OFF/ACC/RUN modes. We ran 125 PSI using an air compressor through the spark plug hole to simulate a starter engaging, nothing but air came out.
With the oil looking like normal oil, and no liquid coming out of spark plug hole (oil in dipstick looked normal to) I assume there is no water in the engine. (Which is good for me)
Are there other things to look out for to know if it is hydrolocked? or if water did get in?
Now, my jeep is in the carport. Even after anight of having all power cut from the vehicle, after connecting power again, it still thinks its on ignition on /accessory mode. Is there a way to do a hard reset on the Jeep? If I can get it back to off position, I may be able to use remote start or start it normally back again.
Update: The jeep is just now showing "Press brake + push to start engine" on dash. Nothing else is on. I follow the instructions and nothing. Sometimes it thinks its on accessory on/ignition on until I cut power again and it will just show "press brake + push to start engine" on dash.
What do I do?
Radio/ac fan uconnect all work. locks/key fob buttons dont work anymore.
jeep is being charged with trickle charger currently
What do I do?
