Namib
I was able to see the test mule up close in Korea today. I was not able to get a good look at the front, but was able to peek under it in the rear. The A-frames looks pretty solid, but very low and short. It is no higher than a standard SUV like a Ford Explorer. It did have 20" wheels with 255/60/20 street tires. The approach and depart angles looks good, but in the rear the exhaust is pretty exposed. This is probably no different than for a Jeep, except that it is a very custom molded design that will be expensive to replace.
This brings me to probably the biggest issue I see. With pretty low ground clearance it will likely need some lift and bigger tires for most enthusiasts. The Independent suspension and unibody type design makes modification very expensive and difficult. I don't think you will even be able to get 33" tires on it as is. I am sure it will be quite capable out of the box, but it leaves no room to make it your own... Forget a lift, bigger tires, mounting a hi-lift, bumpers, adding a winch will likely be challenging etc, I did not see a spare, so it is not clear it will even get a full size spare (can somebody confirm this?)
I think they are shooting at the wrong target...
