azjlur
I had a Rock Krawler 2.5 inch Max travel lift, 37 inch Cooper STT Pros, Fox shocks and a Fox steering stabilizer installed 3 weeks ago. My Jeep has pulled to the right ever since. They did do a four wheel alignment when they installed the lift and tires. I took it back to the shop and they checked everything and said it was fine. They thought it might be the Fox steering stabilizer. Bought a cheaper steering stabilizer and installed it but still had the pull. Took it to a different alignment shop and they said my alignment was perfect and that it must be radial pull from one of the tires. Took it to Discount Tire and had them rotate the 2 front tires and it still pulled. Had them rotate the tires front to back and it still pulls to the right. It’s not severe, but it is annoying and worse at higher speeds. Any ideas on what the problem is?
