Jeep JL Wrangler Wiring Diagrams
Bigbgarage
Amissville, Va
2019 Jeep Wrangler sport S 2 door
Here are some Jeep JL Wrangler wiring diagrams, hope this helps out the community.
Each of the diagrams are in PDF.
To download a zip of all diagrams;
[ALL WIRING DIAGRAMS DOWNLOAD]
Individual file downloads;
AUDIO SYSTEM (BASE) - Wiring Diagram
AUDIO SYSTEM (PREMIUM) - Wiring Diagram
AUTOMATIC SWAY BAR - Wiring Diagram
AXLE LOCKER SYSTEM - Wiring Diagram
BACKUP CAMERA SYSTEM - Wiring Diagram
BACKUP LAMPS SYSTEM - Wiring Diagram
BLIND SPOT MONITOR SYSTEM - Wiring Diagram
BRAKE SYSTEM - Wiring Diagram
CABIN HEATER SYSTEM - Wiring Diagram
CAN C BUS LAYOUT - Wiring Diagram
CAN C BUS SYSTEM - Wiring Diagram
CAN IHS BUS LAYOUT - Wiring Diagram
CAN IHS BUS SYSTEM - Wiring Diagram
CAN PRIVATE BUS SYSTEM - Wiring Diagram
DATA LINK CONNECTOR - Wiring Diagram
DEFOGGER SYSTEM - Wiring Diagram
DIGITAL TV SYSTEM - Wiring Diagram
ELECTRO HYDRAULIC POWER STEERING (EHPS) SYSTEM ESS - Wiring Diagram
EMERGENCY RESPONSE ASSISTANCE SYSTEM - Wiring Diagram
ENTIRE VEHICLE CONNECTOR MAP - Wiring Diagram
FOG LAMPS SYSTEM - Wiring Diagram
FRONT FOG LIGHT CONNECTOR - Wiring Diagram
FUSES / RELAY - ASD - 2.0L - Wiring Diagram
FUSES / RELAY - ASD - 3.6L - Wiring Diagram
FUSES / RELAY - ASD - DIESEL 2.2L - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - 2.0L and 3.6L - ESS - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - 2.0L - eTORQUE - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - DIESEL - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - Wiring Diagram
FUSES / RELAY - RUN / ACC - Wiring Diagram
FUSES / RELAY - RUN / START - Wiring Diagram
FUSES - BATTERY - ESS - Wiring Diagram
FUSES - BATTERY - eTORQUE - Wiring Diagram
GROUND LOCATION LAYOUT - Wiring Diagram
HANDS FREE SYSTEM - Wiring Diagram
HEADLAMPS SYSTEM - Wiring Diagram
HEATED SEAT SYSTEM - Wiring Diagram
HEATED STEERING WHEEL SYSTEM - Wiring Diagram
HORNS - Wiring Diagram
HVAC SYSTEM - ATC - Wiring Diagram
HVAC SYSTEM - MTC - Wiring Diagram
INTERIOR LIGHTING SYSTEM - Wiring Diagram
LAMP ASSEMBLY LEFT-FRONT - C1 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY LEFT-FRONT - C2 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY RIGHT-FRONT - C1 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY RIGHT-FRONT - C2 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY TAIL-LEFT CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY-TAIL-RIGHT CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - LEFT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - LEFT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
LAMP LICENSE CONNECTOR DETAILS - Wiring Diagram
LIN BUS LAYOUT - Wiring Diagram
LIN BUS SYSTEM - Wiring Diagram
LOCK SYSTEM (BASE) - Wiring Diagram
LOCK SYSTEM (PREMIUM) - Wiring Diagram
MEDIA PORT (BASE) - Wiring Diagram
MEDIA PORT (PREMIUM) - Wiring Diagram
MESSAGE SYSTEMS - Wiring Diagram
MIRROR - EXTERIOR - Wiring Diagram
MIRROR - INTERIOR - Wiring Diagram
MODULE - BODY-CONTROL MODULE (BCM) LAYOUT - Wiring Diagram
PARK ASSIST SYSTEM - Wiring Diagram
PARK LAMPS SYSTEM - Wiring Diagram
PASSIVE ENTRY SYSTEM - Wiring Diagram
POWER DISTRIBUTION CENTER AUXILIARY LAYOUT - Wiring Diagram
POWER DISTRIBUTION CENTER (PDC) LAYOUT - Wiring Diagram
POWER OUTLETS - Wiring Diagram
POWER TOP SYSTEM - Wiring Diagram
REAR FOG LIGHT CONNECTOR - Wiring Diagram
REMOTE START SYSTEM - Wiring Diagram
RESTRAINT SYSTEMS - Wiring Diagram
STARTING CHARGING SYSTEM - 2.0L and 3.6L - ESS - Wiring Diagram
STARTING CHARGING SYSTEM - 2.0L - eTORQUE - Wiring Diagram
STARTING CHARGING SYSTEM - 2.2L - ESS - Wiring Diagram
STOP LAMPS SYSTEM - Wiring Diagram
SWING GATE - LOCK-SYSTEM - Wiring Diagram
TIRE PRESSURE MONITORING SYSTEM (TPMS) - Wiring Diagram
TRAILER TOW SYSTEM - Wiring Diagram
TRANSFER CASE - Wiring Diagram
TRANSMISSION - 850RE - 2.0L, 2.2L, 3.6L - Wiring Diagram
TRANSMISSION - MANUAL - 3.6L - Wiring Diagram
TURN SIGNAL LAMPS SYSTEM - Wiring Diagram
UNIVERSAL TRANSMITTER - Wiring Diagram
UPFITTERS - Wiring Diagram
VEHICLE GROUND INLINE CONNECTOR MAP [TOPOLOGY MAP] - Wiring Diagram
VEHICLE THEFT SECURITY SYSTEM - Wiring Diagram
WINDOWS - Wiring Diagram
WIPER / WASHER SYSTEMS - Wiring Diagram
This post helped me find the short in my mirror harness. Fuse 96 would blow if I adjusted mirror up on drivers door with door closed. Bravo!
Hrothgar
Vancouver, WA.
2018 JL Sport 2.0T Ocean Blue, 2002 TJ X 4.0 MT Patriot Blue
Anyone have, or has anyone seen a schematic detailing which pins go to what on the hardtop connector? The one you disconnect to take the top off. I'd like to know what each of them do.
CaptStarboard
Australia
www.brisbanejeepclub.com
2020 Jeep JL Wrangler Rubicon 2.2L TD - "Jacko" Punk'n Orange (Old - 2010 Jeep KK Cherokee)
Amazing. Is there a way to find where exactly these wire are in the Jeep and where they terminate?. Some of course are obvious and labeling is descriptive enough but some are not. I'm trying to track down the Power top power wires. I "think" they terminate in the block of wires in the back in the rear cargo. Has anyone done a breakdown of all the wires in that block? Since I dont have a power top, these could be used for a fridge instead for example.
Or could they power a trailer brake controller or tow hitch wiring harness?... A lot closer than the battery!
Rubycon50
Royce
Glendora, California
2018 Jeep Rubicon JL
Hope this is still useful for you:
BryonL
Bryon
Bridgeport Texas
Dodge Ram
Thats some pretty cool connector information! I’d like to know how to get those. Otherwise, do you have the wiring page for the fuel pump control module? I ripped some wires out and need to know which wires go where.
Rubycon50
Royce
I do I’ll get it to you later tonight
BryonL
Bryon
Bridgeport Texas
Dodge Ram
Hey no need to get that diagram unless you want to post it for the forum. I was able to get the schematic and pin-outs from my local dealer. Thanks for looking into this!
A word of caution for anyone that may drop the fuel tank in the future, there is virtually zero wiring slack between the fuel pump connector and the control module mounted to the frame. Soon as you can lower tank enough to get your hands on the fuel pump connector disconnect it and the two wire harness clips. Otherwise you might risk ripping wires out of the fuel pump control module connector like I did.
BryonL
Bryon
Bridgeport Texas
Dodge Ram
Can somebody tell me what these codes mean where the arrows are pointing to?
Jeep Wrangler JL Jeep JL Wrangler Wiring Diagrams 1597930589115
J5 should be the terminal cavity location within the connector (C2) that attaches to the power distribution center (which is the fuse box under the hood). The 12 represents the terminal cavity location that the particular pink/yellow wire connects to on the back of the front power window switch. The S17034 i believe is a splice. Circuit breaker CB01 supplies power to both the front window switch and the rear window switch if equipped. That 1 large pink/yellow 3.0mm wire comes out of fuse box, then splits (via a splice) into two wires supplying each switch with power it looks like. All of those SXXXXX black Dots with connecting dashed lines in these schematics should be splices sending power to multiple spots as needed. As for connector cavity numbering, some are numbered, some are lettered and some are number/letter combos. The 8-way connector that connects to our fuel pump control module has 8 cavities, they are lettered A thru H. I happened to rip out two wires from cavity D and cavity E. Without schematics and a connector diagram, I wouldn’t have known which wires went where.
BryonL
Bryon
Bridgeport Texas
Dodge Ram
Here’s a few pics to help anyone that may be interested to better understand our weird wiring diagrams (for the record, my old Toyota wiring diagrams and FSM’s are the best ones I’ve ever seen and used)
Below is part of the schematic and connector diagram as mentioned above regarding the hardtop connector.
Jeep Wrangler JL Jeep JL Wrangler Wiring Diagrams 30A42126-E919-4922-B535-9EDBCE97ACC6
As you can see there are two fuses that supply power to left and right side for the power top. And the following picture shows the connector diagram for connector XY440A that reference the exact wires (green/red and orange/red) that terminate in cavities 13 and 14 in that particular 14-way connector. Also notice that between the fuse box (power distribution center) and the power top control module, there are 3 total connectors that the wires pass through. The mentioned XY440A as well as XY401A and XY9000A. The circuit numbers however do not change.
Jeep Wrangler JL Jeep JL Wrangler Wiring Diagrams 6E5D879F-91D1-4554-B076-B4ED1134F72E
daveprice7
Junction City, OR
2019 Sport 2DR, 2020 Willys 2DR
Nerd
I'm scratching my head with the door wiring; it doesn't seem like there are enough wires on the diagram to perform the function(s) - namely the lock/unlock button on the door. Shouldn't there be at least three wires for a three-position switch (common, lock, unlock) or at least two wires if the common is ground? I'm just trying to figure out which wires to tap on the door connector (the one you disconnect to remove the door) that would allow me to mimic the door lock switch.
Morganton NC
2018 Jeep JL Unlimited Sport
I have installed my AMP EXtreme power steps per the wiring instructions they provided but I don't seem to be getting the passenger front door signal. Would you happen to have the pin out for the blue connector on the BCM? I can't seen to get anyone at AMPs Tech Support.
LeodaJeep
Leo
SoCal below Idyllwild mountains S.W. side.
2019 Jeep Wrangler JL Rubican
Self Sufficient
You are AWESOME! Thank you.
LeodaJeep
Leo
Self Sufficient
Since you got the 2018, could you possibly get the 2020? My system is close but not exactly the same. Knowing that the relay is on a non-serviceable PCB helps a lot though. Thanks again.
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Did you ever sort this out? The AMP manual stinks and I'm being polite! Also pre-purchase talk with their support wasn't encouraging.
