Jeep JL Wrangler Wiring Diagrams
x7tristan
x7tristan
TJ
Maryland
I have a Sahara JLU, I'm willing to buy stock alpine from oemmoparparts, is it prewired already and just need to install and connect?
I'm not really sure, you could pull off the right rear interior panel and see if the connector for the subwoofer is there or not...
JL.FR
Casa
France (Europe)
JLU RUBICON 2.0 Turbo MOJITO
Like you said it's an aggregate of all models. You have to read into the details, makes it kind of confusing.
I actually don't know of any Wrangler model that has a turn indicator light in the mirrors. I have also noticed that the diagrams can also include wiring for options not actually offered in the Wrangler, e.g. front bumper proximity sensors in the top level diagram
Hello X7tristan, thank you for this contribution and the answers you give on this thread. It's very very precious , and I inform you that in France we have park assist sensors on the front bumper. A lot of fun with your Wrangler ...
x7tristan
x7tristan
TJ
Maryland
Thats really cool that the EU model has front park assist, I had no idea! Any chance you have a picture of the location of the front parking sensors?
pcpopcorn
Clarkston Mi
2018 JL Rubicon Firecracker Red
That 9 indicates the pin number of a connector. In the "Entire-Vehicle-Connector-Map" there's a legend, a little helpful. And that same diagram, will give you a general idea of where/how the wires are routed through the jeep.
Fantastic and Thank you
On the Entire Vehicle Map it say's you can click on the map to expand.
Can You?
I am trying to find a connection point for the fog lights under the hood near the fuse box to wire in a harness from Baja Designs.
x7tristan
x7tristan
TJ
Maryland
Can You?
Sorry, no. The pdf's I downloaded are not interactive like it is when you use the paid subscription service's tool
JL.FR
Casa
France (Europe)
Yes tristan ... i have 2 pictures , the first is mine , second is a after market (Chinese) steel bumper (like 10th anniversary) with location of front park sensors .
Have nice day and thank you again for the diagrams, if you have other , motor, body or others ....:clap:
EK15
JL
Can someone help me out in identifying which wires connect to
Dashboard lights
RPM signal
Throttle signal
Vehicle Speed signal
cdavison82
Christopher
Austin, TX
2018 JLU Rubicon Granite Mettalic
Im trying to determine what stops the audible signal for blind spot notification when the doors are removed. I assumed the signal was a loop from the blind spot monitor in the tail lamp, to the light in the mirror and then on to something in the computer but it doesn't appear to be the case in the wiring diagrams as they just have a signal wire for blind spot green for driver, green/white for passenger, which I confirmed in the harness. Odd thing is the white/green on driver and white/beige in passenger appear to loop back as there are two of each of these in their respective wiring harnesses at the door disconnect harness. Since the blinker has to be on for the audible to work but doesn't have to be on for the blind spot lamp to work, maybe the blinker wire is the one I want to loop with the doors off? Any thoughts?
Dunigan88
Justin
Borger, TX
2018 Jeep Wrangler JL Sahara Unlimited
Here are some Jeep JL Wrangler wiring diagrams, hope this helps out the community.
Each of the diagrams are in PDF.
To download a zip of all diagrams;
[ALL WIRING DIAGRAMS DOWNLOAD]
Individual file downloads;
AUDIO SYSTEM (BASE) - Wiring Diagram
AUDIO SYSTEM (PREMIUM) - Wiring Diagram
AUTOMATIC SWAY BAR - Wiring Diagram
AXLE LOCKER SYSTEM - Wiring Diagram
BACKUP CAMERA SYSTEM - Wiring Diagram
BACKUP LAMPS SYSTEM - Wiring Diagram
BLIND SPOT MONITOR SYSTEM - Wiring Diagram
BRAKE SYSTEM - Wiring Diagram
CABIN HEATER SYSTEM - Wiring Diagram
CAN C BUS LAYOUT - Wiring Diagram
CAN C BUS SYSTEM - Wiring Diagram
CAN IHS BUS LAYOUT - Wiring Diagram
CAN IHS BUS SYSTEM - Wiring Diagram
CAN PRIVATE BUS SYSTEM - Wiring Diagram
DATA LINK CONNECTOR - Wiring Diagram
DEFOGGER SYSTEM - Wiring Diagram
DIGITAL TV SYSTEM - Wiring Diagram
ELECTRO HYDRAULIC POWER STEERING (EHPS) SYSTEM ESS - Wiring Diagram
EMERGENCY RESPONSE ASSISTANCE SYSTEM - Wiring Diagram
ENTIRE VEHICLE CONNECTOR MAP - Wiring Diagram
FOG LAMPS SYSTEM - Wiring Diagram
FRONT FOG LIGHT CONNECTOR - Wiring Diagram
FUSES / RELAY - ASD - 2.0L - Wiring Diagram
FUSES / RELAY - ASD - 3.6L - Wiring Diagram
FUSES / RELAY - ASD - DIESEL 2.2L - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - 2.0L and 3.6L - ESS - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - 2.0L - eTORQUE - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - DIESEL - Wiring Diagram
FUSES / RELAY - MISCELLANEOUS - Wiring Diagram
FUSES / RELAY - RUN / ACC - Wiring Diagram
FUSES / RELAY - RUN / START - Wiring Diagram
FUSES - BATTERY - ESS - Wiring Diagram
FUSES - BATTERY - eTORQUE - Wiring Diagram
GROUND LOCATION LAYOUT - Wiring Diagram
HANDS FREE SYSTEM - Wiring Diagram
HEADLAMPS SYSTEM - Wiring Diagram
HEATED SEAT SYSTEM - Wiring Diagram
HEATED STEERING WHEEL SYSTEM - Wiring Diagram
HORNS - Wiring Diagram
HVAC SYSTEM - ATC - Wiring Diagram
HVAC SYSTEM - MTC - Wiring Diagram
INTERIOR LIGHTING SYSTEM - Wiring Diagram
LAMP ASSEMBLY LEFT-FRONT - C1 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY LEFT-FRONT - C2 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY RIGHT-FRONT - C1 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY RIGHT-FRONT - C2 CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY TAIL-LEFT CONNECTOR DETAILS - Wiring Diagram
LAMP ASSEMBLY-TAIL-RIGHT CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - LEFT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - LEFT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (BASE) CONNECTOR DETAILS - Wiring Diagram
LAMP - DRL - RIGHT (PREMIUM) CONNECTOR DETAILS - Wiring Diagram
LAMP LICENSE CONNECTOR DETAILS - Wiring Diagram
LIN BUS LAYOUT - Wiring Diagram
LIN BUS SYSTEM - Wiring Diagram
LOCK SYSTEM (BASE) - Wiring Diagram
LOCK SYSTEM (PREMIUM) - Wiring Diagram
MEDIA PORT (BASE) - Wiring Diagram
MEDIA PORT (PREMIUM) - Wiring Diagram
MESSAGE SYSTEMS - Wiring Diagram
MIRROR - EXTERIOR - Wiring Diagram
MIRROR - INTERIOR - Wiring Diagram
MODULE - BODY-CONTROL MODULE (BCM) LAYOUT - Wiring Diagram
PARK ASSIST SYSTEM - Wiring Diagram
PARK LAMPS SYSTEM - Wiring Diagram
PASSIVE ENTRY SYSTEM - Wiring Diagram
POWER DISTRIBUTION CENTER AUXILIARY LAYOUT - Wiring Diagram
POWER DISTRIBUTION CENTER (PDC) LAYOUT - Wiring Diagram
POWER OUTLETS - Wiring Diagram
POWER TOP SYSTEM - Wiring Diagram
REAR FOG LIGHT CONNECTOR - Wiring Diagram
REMOTE START SYSTEM - Wiring Diagram
RESTRAINT SYSTEMS - Wiring Diagram
STARTING CHARGING SYSTEM - 2.0L and 3.6L - ESS - Wiring Diagram
STARTING CHARGING SYSTEM - 2.0L - eTORQUE - Wiring Diagram
STARTING CHARGING SYSTEM - 2.2L - ESS - Wiring Diagram
STOP LAMPS SYSTEM - Wiring Diagram
SWING GATE - LOCK-SYSTEM - Wiring Diagram
TIRE PRESSURE MONITORING SYSTEM (TPMS) - Wiring Diagram
TRAILER TOW SYSTEM - Wiring Diagram
TRANSFER CASE - Wiring Diagram
TRANSMISSION - 850RE - 2.0L, 2.2L, 3.6L - Wiring Diagram
TRANSMISSION - MANUAL - 3.6L - Wiring Diagram
TURN SIGNAL LAMPS SYSTEM - Wiring Diagram
UNIVERSAL TRANSMITTER - Wiring Diagram
UPFITTERS - Wiring Diagram
VEHICLE GROUND INLINE CONNECTOR MAP [TOPOLOGY MAP] - Wiring Diagram
VEHICLE THEFT SECURITY SYSTEM - Wiring Diagram
WINDOWS - Wiring Diagram
WIPER / WASHER SYSTEMS - Wiring Diagram
I've used this info more times than I can count. Thank you!!
Nordy
Mitch
Wisco
JL Rubicon Blue
Another resource if you need to find pin outs of connectors or buy pigtails (most don't exist yet) Was looking for automatic sway bar connector and have yet to find one in existence. Anyone know who manufactures it? doesn't look like a molex part like most of the connectors on the vehicle.
http://connectors.dcctools.com/results.htm
