JEEP JL SPARE TIRE DELETE TAG MOUNT
Status
Not open for further replies.
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
I don't see any reason to add anything as we've never had an issue with any of our tag kits scratching the paint, but I don't see it causing any issues if you decide to install some.
Cody6597
Elliott
Houston
Jeep JL Unlimited Rubicon
Hi all. I completed the install but my back up sensors are now not working? Did I miss a step?
Thanks
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
Give us a call to discuss your install. 334-219-2333
Waiting
Keith
Baltimore
2018 2-Door Rubicon, 3.6L, 8-spd auto
Any issue or any reason not to add felt between this and the tailgate in order to prevent scratching etc.?
Isn't the outer skin of the tail gate aluminum? If so, minor scratching, if any at all, won't rust the tail gate. If Motobilt plate is removed, it would be covered by another tail gate plate/tire carries, etc; and you could always use a little touch up paint.
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
We appreciate all the orders!
David F.
Griffin Ga.
2018 Wrangler JL
Any plans to allow for the removal of the M for maybe a custom shape? Id pay a few extra bucks for a Punisher skull there.
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
We are a production based manufacturer much like an assembly line, so we are not able to make one off kits. We appreciate your interest though. in our products.
Sincerely,
Motobilt
GinjaNinja
Aaron
Snoqualmie (Western WA)
2021 Gladiator Mojave; 2018 Mojito! JLUR [GONE];
Are good friends at ORO just came out with installation instructions for the third brake light and tag light kit that we sell with our tag delete kit.
Check it out by clicking here!
https://www.motobilt.com/sites/default/files/LitePLATE-wiring-for-Wrangler-JL.pdf
Hey guys, I just got around to wiring mine up and wanted to let you know there is a significant typo in the instructions. The wire color summary at the end of the doc is wrong...the red wire goes to the tailgate bundle and the green wire goes to the taillight connector. I had to rerun and rewire the connections. The wire colors in the step by step instructions are correct however.
Cheers.
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
Cheers.
Thank you for bringing this to our attention.
This should be to corrected setup
https://www.motobilt.com/sites/default/files/LitePLATE wiring for Wrangler JL .pdf
Cody6597
Elliott
Houston
GinjaNinja
Aaron
Could this be why my backup sensors are not working? Also any updates or options to get the camera pointed down at the proper angle?
This should not affect your backup sensors at all. You might be able to shim the camera a bit to help correct but not sure. They would need to increase the angle downward on the mounting plate for it to be truly fixed
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
The angle of the mount is different then the factory setup slightly so that it will line up properly. The back up sensors should not be affected by the tag/camera mount.
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
Thanks again for all of the orders!
Status
