Jeep JL Rubicon Dana 44 Diff Covers $99
Thread Status:
Not open for further replies.
  1. Motobilt
    Motobilt Well-Known Member
    First Name:
    Bobby
    Vehicle(s):
    2018 JL Rubicon
    Jun 11, 2018
    Dothan, AL
    420
    Liked:
    328
    #1 Jun 14, 2018
    The Motobilt Jeep JL Rubicon Front Dana 44 heavy duty teel diff cover has many features that separate it from others. Our diff cover features a 3/8" thick steel ring that will keep the cover from pulling away from the housing when dragging over rocks. The Jeep JL front Dana 44 HD steel diff cover also features the proven 1/4" thick steel plate design with an integrated 3/4" NPT fill plug. The fill plug on the Jeep JL Rubicon front Dana 44 HD steel diff cover allows for easy access, especially when a truss system is commonly used. The diff cover is welded both on the inside and outside of the cover to ensure maximum penetration for superior strength. The steel diff cover's design comes from over 14 years of diff cover testing and manufacturing experience. The diff cover ships bare steel and will need to be painted. We do not usually powder coat ours because the diff cover is going to take abuse from rocks. Spray paint works well so you can simply touch it up. The bolts and fill plug ship with the cover.
    The diff cover has ample clearance for HD aftermarket steering kits also. No worries if your new steering kit will clear our diff cover.
    Fits Jeep JL Rubicon FRONT Dana 44 only
    If you want to purchase the matching front diff cover then you need part number MB4073
    The Motobilt Jeep JL Rubicon Rear Dana 44 heavy duty teel diff cover has many features that separate it from others. Our diff cover features a 3/8" thick steel ring that will keep the cover from pulling away from the housing when dragging over rocks. The Jeep JL Rear Dana 44 HD steel diff cover also features the proven 1/4" thick steel plate design with an integrated 3/4" NPT fill plug. The fill plug on the Jeep JL Rubicon rear Dana 44 HD steel diff cover allows for easy access, especially when a truss system is commonly used. The diff cover is welded both on the inside and outside of the cover to ensure maximum penetration for superior strength. The steel diff cover's design comes from over 14 years of diff cover testing and manufacturing experience. The diff cover ships bare steel and will need to be painted. We do not usually powder coat ours because the diff cover is going to take abuse from rocks. Spray paint works well so you can simply touch it up. The bolts and fill plug ship with the cover.
    Fits Jeep JL Rubicon REAR Dana 44 only
    If you want to purchase the matching front diff cover then you need part number MB4075
    The Motobilt E locker guard for the Jeep JL Rubicon rear axle protects the harness for the locker. Made of 3/16 inch steel plate this guard will protect the wiring harness plug that goes into the top of the differential. This setup bolts in using 2 of the differential cover mounting bolts.
    Features:
    • Made of 3/16 inch steel plate
    • Ships raw metal and will need to be painted
    • This guard will protect the wiring harness plug that goes into the top of the differential
    laraza2k1 and AmericanMule like this.
  2. Kevin8086
    Kevin8086 Well-Known Member
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
    Installed and ready to hit the trails today.
  3. JLUSoCal
    JLUSoCal Well-Known Member
    First Name:
    Vehicle(s):
    Nov 4, 2017
    342
    Liked:
    231
    Occupation:
    IT
    Garage Profiles:
    Did you paint the logo red? - will look great with your JLUR in red!
    AmericanMule, Motobilt and Kevin8086 like this.
  4. Kevin8086
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
    Yup. Painted it red and used matte clear coat on the whole cover
    AmericanMule and Jeepin_Donnie like this.
  5. OBJLU
    OBJLU Well-Known Member
    First Name:
    Henry
    Vehicle(s):
    2018 JLU Rubicon
    Jul 23, 2018
    Los Angeles
    127
    Liked:
    47
    How much diff oil do we need to add and do the instructions come with torque specs? I ordered myself one.
    Thanks!
    Kevin8086 likes this.
  6. Kevin8086
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
    I’d have to look it up but I think k 25lbs tq
    2qts of oil for each axle. Make sure you buy the front and rear cover and the locker switch protector
    Motobilt and OBJLU like this.
  7. OP
    Motobilt
    First Name:
    Bobby
    Vehicle(s):
    2018 JL Rubicon
    Jun 11, 2018
    Dothan, AL
    420
    Liked:
    328
  8. Kevin8086
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
    JLUSoCal likes this.
  9. Kevin8086
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
  10. Martindfletcher
    Martindfletcher Well-Known Member
    First Name:
    Martin
    Vehicle(s):
    Ducati 1299s, 2018 JLUR
    Jan 3, 2018
    San Diego
    1,450
    Liked:
    1,231
    Don’t forget locker additive.. not positive it’s needed with synthetics, the but the kid at autozone (yes I know) said it was best to add it. Have not watched the video yet.
  11. Goin2drt
    Goin2drt Well-Known Member
    Vehicle(s):
    18 Rubicon, 17 Grand Cherokee Trailhawk
    Oct 25, 2017
    Kentucky (formerly Peoples Republik of Kalifornia)
    1,433
    Liked:
    1,486
    These are hot. I want. Will add to the mod list for sure. Not that I think I will need them but they look killer.
  12. Kevin8086
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon
    Mar 5, 2018
    469
    Liked:
    1,243
    Usually additive is for a limited slip rear end. The rubicon doesn’t have that. It’s just gears and a locking mechanism
  13. Martindfletcher
    First Name:
    Martin
    Vehicle(s):
    Jan 3, 2018
    San Diego
    1,450
    Liked:
    1,231
    Your right I misread the manual as well. I was only wondering if you needed it with synthetic or not.
  14. FrankieFJL
    FrankieFJL Well-Known Member
    First Name:
    Frank
    Vehicle(s):
    2018 JL Rubicon
    Mar 28, 2018
    Massachusetts
    351
    Liked:
    339
    Occupation:
    IT Professional
    Garage Profiles:
    With a Labor Day discount I couldn't pass up, I ordered the pair along with the switch protector. They look massive, just what I was looking for at a reasonable price. You can never have enough unsprung weight! LOL
    bikenutty and Kevin8086 like this.
  15. OP
    Motobilt
    First Name:
    Bobby
    Vehicle(s):
    2018 JL Rubicon
    Jun 11, 2018
    Dothan, AL
    420
    Liked:
    328
    We appreciate the business. We shipped several of these yesterday and are making more now. We had a ton of orders.
    laraza2k1, Kevin8086 and FrankieFJL like this.
Loading...
Thread Status:
Share This Page
