Jeep JL Headlight Adjustment - How To Aim Headlights After Lift or Replacement
cohocarl
Carl
Mid-Michigan
'21 Honda Passport, '18 Crosstrek, '16 Cherokee
If you lifted your Jeep, do this. Don't blind everyone.
Thanks for the video! I was getting flashed in my stock JL Sport S, so I read in another post here that turning the adjuster CC brings the beam down, so I turned it 1.5 turns CC. Still got flashed. Turned it another turn. Still getting flashed...
In your video @ 2:30, it's mentioned that turning the adjuster CW brings the beam down...
Due to the oncoming flashing I'm getting after turning them 2.5 turns total CC, I'm guessing that's wrong and need to go the other way, CW.
I'll have to try your tape on the garage door trick.
Thanks!.
@RogueKJ
To adjust:
When you adjust, have your headlamps on LOW beam, not bright beam.
Looking down at the adjuster's, you turn them clockwise (turn to the right) to go UP and counter clockwise (turn to the left) to go DOWN.
This would be the opposite if I'm understanding it correctly.
cohocarl
Carl
Mid-Michigan
Just a follow-up. I turned them 2.5 turns CW back to "stock", then 1 1/2 turns CW. Haven't been flashed once since...
Jeep Generation
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Thats great. Glad it worked out. I dont think I mentioned how many turns. It would depend on your lift, tires, weight of bumpers and such to determine how much you need to turn it. You need to get the mark on the wall and measure it at 3' from 25' back.
msujedi
Jed
Michigan
2018 JLU Sport S Firecracker Red, 2014 Durango, 1999 Honda CRV
Assuming everyone's JL is 'level' after lifts, tires, etc ... a certain number of turns should lower the beam a certain number of inches (at 25' from a wall).
I don't feel like figuring out that ratio now that mine are already adjusted. So, I'm just throwing this out there for the next person who adjusts their beams. It might save others time to know that, for instance, 2.5 turns results in lowering the beam 4" (fictional example). With that info, they should be able to set their beams to the right height just based on knowing their extra height from their lift & tire.
HoundDude
New Jersey (i know, i know, i'm stuck here)
2019 Wrangler JL Sahara
@RogueKJ
... Do know that your fog lights also can also be adjusted as needed. Each fog light has an adjuster.
where is the adjuster for the LED fog lights? there is no access opening in my JLUS plastic bumper. i mostly removed the plastic shield behind the bumper that covers the fog lights, and looking in through the opening it's not obvious there is an adjustment point. it would be nice to know what I'm looking for before i take everything apart. thanks
Jeep Generation
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
There is a dial you turn. You can see it in this video when I installed my steel bumper. The light wouldn't fit until I turned the dial. The plastic bumper is a pain to access the fog lights. You need to take it all part to get to them. I also dont have LED fogs, so it might be slightly different.
HoundDude
thanks for linking the video, appreciate it!
I see the adjuster you're talking about. the back of my LED lights look a little different but i think I do see a little wheel. but now I'm thinking if I'm gonna do all that work, i might as well install a steel bumper too :)
toddbrosen
Todd
Warwick
2020 Sport
Is the process the same for the 2020 JL Sport without the led package? I cannot find the screws to lower the headlights for the life of me. I'm thinking if no Led package, maybe the screws aren;t there?
msujedi
Jed
Michigan
Screws should be in the same spot on the 2020 JL Sport as on my 2018 JL Sport. They are off-white in color. The screws are made to accommodate either a hex wrench (not sure of size) OR a phillips screwdriver.
Austingobi
Vinny
Austin, TX
2020 Gladiator S
So, no left and right adjustment ? Mine seem to be joining in the center. Would like to get drivers side to the right a bit.
Jeep Generation
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
I could be wrong, but I think the only way to move them left and right is if you take the grill off and mess with the screws that are holding in the lights. I think Jeep only wants people adjusting up and down.
SRQgunner
Russ
Sarasota FL
2018 Jeep Wrangler JL Unlimted Sport S
I had my factory LED installed by the dealer a few weeks ago. I've been getting flashed by oncoming vehicles as though I had my high beams on. I did the 25'/3' test and sure enough I'm about 4' on the wall.
I tried to adjust using the white screw wheel but nothing happens the beam won't go up or down. Same result when I tried adjusting both lights.
I'm very certain I have the screwdriver in correctly as I can see the white wheel turning also.
Am I not doing something correctly ? Solutions?
Northridge4x4
