Zandcwhite
Zach
Patterson, ca
2019 jlur
You have that exactly backwards, low range first gear gives the tires minimum mechanical advantage, if the road surface was wet theres a good chance they wouldn’t have turned at all.
You do realize gearing works in both directions? The same gearing that gives the engine maximum torque to the tires gives the tires maximum torque to the engine when the wheels are being driven and the engine is off.
cnapierala
Omaha, NE
2020 JLR
So do you think they got to their destination and tried to start it before they figured out there was a problem? Just imagining the poor folks popping the hood to see what was going on all to see half the engine gone! Ha ha!
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Yep, 4lo and 1st gear gave it highest engine compression ratio.
This is why when descending from a hill, putting it into 4lo and 1st gear can maximize your engine braking.
I'm surprised they didn't realize how difficult it was to tow that damn thing before it reached 70mph.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Compression ratio doesn't change with gearing. If it takes 50ftlbs to turn the crank with the engine off the torque multiplication reduces the effort at the wheels to turn the motor over. Picture a longer ratchet on the crank bolt, that is what the gearing was doing.
Arterius2
Jerry
Vancouver, BC
I don't think that's the case here.
Imagine descending off a hill, you put the vehicle into 4lo and 1st gear to maximize engine braking, providing highest rolling resistance.
Just replace that downward descend force with a vehicle trying to tow you, you would still offer highest rolling resistance to that said vehicle towing you. No?
Zandcwhite
Zach
Patterson, ca
2019 jlur
Engine braking doesn't work with the engine off. With the engine off the drive train is just a lever on the crank shaft. More gearing, larger lever.
Arterius2
Jerry
Vancouver, BC
Sure it does.
Imagine 2 scenarios (with wheels spinning 1 full revolution when towed):
Scenario A (low gearing) - small gear turning a larger gear with 3x more teeth - small gear turns 1 rev, large gear turns 1/3 rev, due to the force multiplying nature of the gearing system, relatively less force is required to turn the small gear 1 rev.
Scenario B (high gearing) - large gear with 3x more teeth turning a smaller gear - large gear turns 1 rev, smaller gear turns 3 revs, you would feel 3x more resistance at the input end of the large gear.
When towing the Jeep in 1st gear, it would be something akin to scenario B.
Sydwaiz
Torrance, CA
2021 JLURD, 73 CJ-5
Whut? The engine is still compressing air in the cylinders even if you aren't adding fuel and ignition. That is engine braking. Do you think the valves miraculously remain open when the engine is off letting the motor spin freely with no compression?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
The valves in the Jeep in the original post definitely remained open.....🤪
Zandcwhite
Zach
Patterson, ca
2019 jlur
Sure it does, the nature of the cantilever/pulley system still exist when engine is off.
I was definitely thinking of that backwards, force multlication vs force division. It would take 80 times the force to turn the engine from the wheels. That 10 ftlbs it would take to turn the crank would be ~800 ftlbs at the wheels. Regardless, the wheels would rotate under enough force which is why on an auto I always leave the trans in park so that nothing upstream of the t-case can be spun when flat towing.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Rather, engine braking is minimal at low rpms. Which is why lower gears increase engine braking as the rpms are higher.
Petey
Pete
Miami
2020 jl sport manual
I was eating noodles for lunch and when I read this on the drive and I literally laughed so much I got noodles coming outta my nose.
I am a noob when it comes to vehicle but heck I would do enough research before doing stupid $hit like that!! :LOL: :LOL: :LOL:
Look at their engine!! Look like a relic that came out from some Aliens movie!!! Hahaha.
P.S: Noodles from my nose! No I am not eating that!
thats not a noodle sir ..please see a doctor
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Being in a higher gear will give more mechanical leverage to the tires over the non running motor. Think of push starting a vehicle. If it was in 1st when the clutch gets popped, the vehicle would abruptly stop and the poor soul pushing it would eat the trunk. The trick was to have it in, say 3rd, and once it fires the clutch is pushed in before it stalled due to being in too high of a gear.
Clayton Offroad
