emgeesea
- Marc
- Apr 19, 2020
- Portland, OR
- 2020 Willys
- Vehicle Showcase
- 1
I have noticed that when connecting my iPhone (11) via any USB port in the JL music skips, usually at the start of songs, but does not do so when playing the same source via Bluetooth. Others have reported the same issue. I am wondering whether going to a wireless connection like this solves that issue, or if it would remain because the wireless component is still using a USB port.I love that the JL has Apple CarPlay, but hate the cords hanging out all over. So I bought a CarPlay2Air, to connect via WiFi. I tried using the port in the center console with the CP2A but had connectivity issues on that port, so I was using the media port below the radio. I was not at all satisfied with that setup. So I did a little in line mod, best of all it’s all plug and play.
Items needed:
1. Carplay2Air adapter
2. Female USB to Female USB adapter
3. AXXESS - USB Adapter Wiring Harness for Select 2010 and Later Vehicles - Multi
4. USB A to mini USB
5. Any double sided sticky tape or Velcro
Steps 1 and 2 remove panels. You shouldn’t need to completely remove panel 1, just pop it loose. The pop off the radio/climate control panel, pull from the corner near the engine start/stop button.
Remove radio/climate control panel and then remove screw 3, I recommend leaving all wires connected to the panel, so you can power up the radio when you are testing. Then pull out window switch panel but don't completely remove it. You only need to pull the panel out far enough to access the cable plugged in above the media port. (See next picture)
Find cable (4) to remove press clip on back and pull up. You will no use the cable with the white connector. If you attempt to use the cable with the white connector it will not work properly.
Here you will attached the AXXESS - USB Adapter it will connect to the cable you just unhooked.
Insert the mini USB side of the cable into the port where you just removed the stock cable from.
Now its time to piece everything else together.
Secure Carplay2Air in the below location. It keeps it up and out of the way. Manage your cables and tuck them in so they are out of the way of the control panel.
Once it's all connected and secured, make sure its working and close it all back up.
All Done!!!! Works perfect.
Hit me up if interested or need help setting yours up.
Any thoughts? Thanks,
