WhereRU_A-A-Ron
Old style on my 2021 JLU Willys.
1C4HJXDGXMW572681
In that scenario I would pull 2021 off the Amazon listing and use the pics of the mat on the JL forum to explain. Shoppers on Amazon don't do enough research and the bad reviews would destroy the product.Would be easier to add the lower mat photos to your description and tell customers to verify which mat they have and state which listing is for which console. Some will still get it wrong because they do not read but at that point you did everything you can to let the person know.
I have this organizer (both parts) and itās helpful and quality. I highly recommend it.Watching Didnāt know of this product and am waiting for my ā21 JL-R to be built. Will definitely want something like this for my Jeep
I have a 2021 JLURD with all of the electronics including the front camera. My bottom console has this mat:Jeep gurus help.....why are there two different center consoles on 2021 models?
Can you post your VIN and build date?I have a 2021 JLURD with all of the electronics including the front camera. My bottom console has this mat:
Build date: November 2020.Can you post your VIN and build date?
I bet the 2-door will never get whatever feature causes the console change.My 2021 2 door Rubicon also has the "old" one. Purchased in Oct 2020. Below is my VIN and options, to maybe help eliminate options you think could be tied to it:
The bottom part of the console is actually smaller front to back than the old style. The organizer center (front to rear) divider is too long to fit in the new console. The top part where the upper organizer goes is the same size as the older console.My 2021 2dr Rubi (built Dec 10, 2020) has the old style. The deep notch of the old style is to accommodate the manual brake lever. Did something change there and the console expanded because it could? I don't have the new style to compare.
Also not as deep!The bottom part of the console is actually smaller front to back than the old style. The organizer center (front to rear) divider is too long to fit in the new console. The top part where the upper organizer goes is the same size as the older console.
