Jeep Fire In Mojave - Need Assistance / Advice Please
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Network/Systems Engineer
About a month ago, driving down a washboard trail, All the warning lights in the jeep went off all at once, and the dreaded message about turning off the engine, the engine will stop shortly popped up on the center screen between the tach and the speedo. I made a U turn and high tailed it back to the main road, which was only a mile away. The main alternator cable vibrated loose and came to rest on the exhaust manifold just in front of the catalytic converter, melted the insulation, promptly shorted, then caught fire! I got the fire put out in short order.
The picture is the Alternator cable disconnected from the PDC fuse bus (7)
Jeep Wrangler JL Jeep Fire In Mojave - Need Assistance / Advice Please altwire-
I installed a Genisys dual battery system in my JLUR a year or so ago. ( the directions said to tuck that cable below all the others, and I didn't realize there was enough slack in the cable to reach that part of the engine) I'm not placing blame, I should have known better ( ignorant me)...
I was out in the Mojave desert (on my way home) when it happened, 217 mile tow cost me a fortune.
Anyway I just got the jeep put back together after going through all the wiring in the vicinity of the fire (it all survived) I was able to get the fire put out fast, nothing else was burnt. ( consequently, for peace of mind, I also re-did all the wiring I installed for all the lights, winch, fridge, all the rest of my gadgets and doodads, ran it in split loom, and secured it to the point of absurdity)
I have tested my alternator for voltage, and it hits 14.5 volts, but that voltage never gets to the battery. I tested the battery voltage with the engine running and it stays at 12.1 to 11.9 volts. That kind of tells me that the alternator isn't charging the system... Also after I let the jeep idle for about 2 minutes the warning about stopping the engine comes on again... Would this main bus fuse come into play (68368853AA I don't have the tow package or Aux switches )
thanks for any help!
MEHillwalker80
Tom
Maine
2019 Wrangler Sport S JL 2 DR 1999 Chevy Suburban K1500
Check the metal fuse array that acts as the set of terminal posts on the main fuse panel/box. one of those could have blown when the original event occurred. They are fusible links that melt when blown. I think you can see whether or not all seven of the links are intact.
WTFSoCal
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Thanks for the response, that was another question in my mind, how to tell/test if that fuse block ( the one I was referring to by the part number) had failed... Ill have to pull it out and have a look. In the mean time Im going to drop by the local dealership and hope they have one in stock, Ill buy 2)
thanks!
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
You probably blew the alternator fuse at terminal t, use a meter to check for continuity to terminal 2.
WTFSoCal
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
OK thank you, I know the terminals are numbered ( if standing on the passenger side reading from right to left) 1 though 7 , 4 being empty... which is "t"
thanks for the reply!
WTFSoCal
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Where is Terminal T, is that the one that the alternator is connected to? I thought it was 7 ?
WTFSoCal
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Thanks Jerry ! I did run to the dealer and bought a couple of those fuse arrays and checked the continuity from the alternator lug to the number 2 lug and sure as hell, no connection... replaced the fuse and ran the jeep for 15 minutes and the battery was charging.
thank you for the hand!
Jebiruph
Jerry
Iowa
Did you verify the part number on old fuse array to make sure you got the right replacement?
