Jeep dealer will not put clutch or transmission under warranty (<50k miles)
zrickety
2020 Rubicon Sarge 2DR 3.6L 6MT
Technician
It sounds like you have a real case against them. I would look for a more reputable dealer, try google reviews. Even if the clutch is wear and tear, your trans should be covered by the warranty. Offer to buy the clutch and have them put it in with a new transmission. A few hundred bucks out of pocket is your best compromise.
Worst case, you find a mechanic buddy and buy one from LKQ roughly $1700. 2 in the country.
Jhawth
Jake
Minnesota
2021 JLUR
Did you have the recall done on your transmission?
AlamedaJeep
Jim
Alameda, CA
2018 Jeep Wrangler JL Unlimited Sport S
Yup, both have them have been done
Since the second recall was a software update, the only obvious sign that it was done is the appearance of the gear indicator above the odometer. Do you know if that was present, which would help confirm that the recall was done correctly?
Scott.B
Alaska
2020 Unlimited Rubicon, 2022 JLURD Ordered
Sue them. Per se.
It is not difficult. Not even expensive.
TroyMclure
Springfield
Schwinn
Yikes. So it sounds like Stellantis' software kludge to prevent excessive clutch slippage isn't working in real life. And it seems JL's out there with a manual transmission are still potential grenades.
Maybe Stellantis should market these Jeeps as a weapon for the military.
Hothead Headliners
