UtahDirt
Yeah jump right in, be a beta testerOh my god! Thank goodness the new Ford Bronco is coming out soon.
If they left a wire on the loose side or a plug not seated, doubt they will tell you. Thats too much of a coincidence, worked on the system recently now a failure.Hey guys so I have the 2.0 Turbo E torque and you guys are right should of handled the power steering going off better. I guess its just the fact its a 1 year old car that pissed me off and my wife and kids not making the situation better. I did have the AUX switched earlier this year due to my start and stop system not working properly. We shall see what they say tomorrow.
Still feel the car shouldn't put you in those situations.
No Yeah I still love the car. It's the funnest car I've had. Just have to handle this properly and make sure it doesn't happen again.Definitely sucks to have this kind of issue. Especially with family in the car. Glad you made it out ok. I will say that even through a buy back for death wobble, Ive never felt unsafe in either of my Saharas. Unfortunately three weeks ago I slammed into the back of someone when a fire truck pulled into an intersection. The Sentra I creamed was totaled. I had a few scratches on my front (plastic) bumper. Ill take it, plus the fun other aspects of owning a Jeep.
Good luck with yours!
Owned 30 cars and trucks before I ever saw power steering.... Yeah it gets your attention. But OP says himself that he "panicked"........ It's a PITA when that shit fails. It's not a near death experience.To many people have never driven a vehicle without power steering or power brakes and freak out when theirs goes out. This sort of failure can happen and as a driver you should be able to handle it without drama.
ESS has little to nothing to do with your fuel economy, it’s about the stuff that gets spewed out your tail pipe.Yep, thanks ESS.. what a crock that feature is. I get the same, or better mpg with it disabled. I can only imagine trying to change lanes in an emergency situtation in LA. I've had to do that a few times and yes, people try to drive around you at high speed. The first thing you do is hit your emergency flashers and slow in your lane.. then slowly get over with your emergency flashers activated.
If the ESS battery was dead, or was at low charge, then wouldn’t you see the dash message for “ESS not available at this time,” or something along those lines? I had a faulty vacuum hose and pump associated with my brake system that negated my ESS and ESC after coming to the first stop during a drive and it would stay that way until the computer reset like when your speakers go into “mysterious FCA low volume mode”. I tend to agree with this post that it might be a wiring issue, a short or grounding of sorts.Your jeep is having a coms issue, basically, all of the different modules use a common pair of twisted yellow wires to communicate. There is interference from something. Could be a bad battery, could be the twisted yellow wires somewhere have rubbed against something and are now shorting to ground. The voltage going through the communication wire is extremely low so there is no danger of fire, but imagine making a phone call on an old landline and someone starts a dial-up modem. The systems can't communicate and the whole system goes into limp mode.
The brakes and steering on a Jeep are still driven directly by your inputs... ie you turn the steering wheel and there is a direct connection between you and the front tires. You hit the brakes and there is a direct result. If this had been a tesla...
driving a a modern vehicle with electric steering that dies is not the same as driving and old non assist steering...Owned 30 cars and trucks before I ever saw power steering.... Yeah it gets your attention. But OP says himself that he "panicked"........ It's a PITA when that shit fails. It's not a near death experience.
The ESS does not improve mpg. It improves gallons per hour, which somehow meets fuel standards.Yep, thanks ESS.. what a crock that feature is. I get the same, or better mpg with it disabled. I can only imagine trying to change lanes in an emergency situtation in LA. I've had to do that a few times and yes, people try to drive around you at high speed. The first thing you do is hit your emergency flashers and slow in your lane.. then slowly get over with your emergency flashers activated.
Yeah, it's all techy stuff like steering box ratios, caster sittings, etc. It has a steering wheel must be the same right?driving a a modern vehicle with electric steering that dies is not the same as driving and old non assist steering...
Just wait until you have your alternator go out on the highway. Then everything shuts down and car rolls to a stop. Fun times.To many people have never driven a vehicle without power steering or power brakes and freak out when theirs goes out. This sort of failure can happen and as a driver you should be able to handle it without drama.
There's this lever right next to the driver's seat, called an emergency brake. With the release button pushed in, lift it up to apply brakes. That in conjunction with the non-assisted power brakes should give you plenty of control. "Freaking out" doesn't do you any good.Yeah rolling at 80+mph in LA (or Austin/San Antonio I35 in my case) w/o ps/brakes. Talk about pucker...
As for no power steering, lot's of cars are actually power assisted steering where the faster you are going the less assistance you get.
Having things fail isn't optimal, but the more car manufacturers dumb down the cars the less people actually DRIVE and become vehicle pointers.
Combine some defensive driving skills into your routine and you will be safer as well regardless of what happens.
Had everything fail on my F350 diesel when the vacuum pump failed - twice as large and heavy as any jeep - and not a big deal. People today are spoiled with auto everything...I've had power steering and power brake failure on every vehicle I've owned except my JLURD because it only has 1,000 miles. I fully expect my power steering and power brakes will fail on my JLURD at some point. Not if, but when.
