Jeep Alarm goes off when Flat Towing with Doors locked
mgarcia4422
mike
Palm Desert, CA
2021 Jeep Rubicon
Can anybody confirm how to flat tow my 2021 Jeep Rubicon behind my motorhome with the doors locks and the alarm not going off 5 minutes down the road? I currently just leave the doors unlocked but need to figure this one out! Thanks for your help. Mike
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Higher Education
Do you have additional alarms, such as for battery level or hood?
Once you have it in (transfer case) neutral and (transmission) park, you are cycling to turn off the power, yes?
Page 177 of the 2023 Manual:
1. Bring the vehicle to a complete stop on level ground.
2. Press and hold the brake pedal.
3. Shift the automatic transmission into NEUTRAL or
press the clutch pedal on a manual transmission.
4. Turn the engine off.
5. Shift the transfer case lever into (N) Neutral.
6. Start the engine.
7. Shift the transmission into REVERSE.
8. Release the brake pedal (and clutch pedal on manual
transmissions) for five seconds and ensure that there
is no vehicle movement.
9. Repeat steps seven and eight with automatic
transmission in DRIVE or manual transmission in
FIRST gear.
10. Turn the engine off.
11. Firmly apply the parking brake.
12. Shift the transmission into PARK or place manual
transmission in gear (NOT in NEUTRAL).
13. Attach the vehicle to the tow vehicle using a suitable
tow bar.
14. Release the parking brake.
Without the power and set properly it should not alarm.
mgarcia4422
mgarcia4422
mike
Palm Desert, CA
2021 Jeep Rubicon
Thanks for the feedback JJ_WA. I have followed these exact steps but if i lock the doors and leave the ignition in the off position, the security alarm (horn) will continue to go off while i am driving. I think it thinks I am stealing the Jeep? Thoughts. I believe there is a way to deactivate the anti-theft alarm for flat towing? but not sure how to engage?
JJ_WA
JJ
Higher Education
Are you leaving a set of keys in the Jeep by any chance? If so it'll get weird when you try to lock up. Otherwise, I'm not sure. Sorry.
mgarcia4422
mgarcia4422
mike
Palm Desert, CA
2021 Jeep Rubicon
no fob/key left in jeep. thanks for the replies….. hopefully someone else has come across this issue and figured it out
Red Willy
Jim
SW Florida
2023 Jeep Beach High Tide, 2021 2 dr. Willys stick
Professional Nobody
That's weird. I have flat towed 2 different JK's and 2 different JL's over the past 6 years and have never had an issue with the alarm going off. I just put the transfer in N, put the auto in park or 6th if manual, turn off the ign, lock the doors and set off.
roaniecowpony
Retired Engineer
Do you have the OEM tow harness or aftermarket?
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
Heavy Equipment
Hey OP,
Try single clicking your FOB.
On my 2020 JL, one click locks the doors, two clicks flashes my lights, gives a quick beep and arms the theft awareness.
If you’re in a hurry and don’t want to troubleshoot, lock the critter old school with a key OR disconnect your batteries.
