Skippy477
- John
- Apr 21, 2021
- Pennsylvania
- 2021 Wrangler Sahara 4xe
Mopar bug and stone guard fits (very easy to install as well)
Part numbers or links would be awesome for all of these - I’ll add them to the front page. Thanks!I can confirm the LOD Armor Lite rock sliders mount up no problem. Got them installed last weekend, including the extra optional self-tapping bolts.
Rock Hard 4x4 Rear LCA bolt-on sliders and Metalcloak's trailer harness slider worked no problem as well.
Another confirmation that the Quadratec dead pedal does not fit. However, I pulled out the grinder and am trying to modify it to fit using some washers and a coupling nut with threaded rod on the firewall stud. Will update if I'm able to get it to work.
Part numbers or links would be awesome for this - I’ll add it to the front page. Thanks!
Mopar 82215367. No modifications were needed.Part numbers or links would be awesome for this - I’ll add it to the front page. Thanks!
Got it - thx. Confirming that you did the rear track bar. The front track is one digit different. Let me know.Teraflex HD Forged Trackbar 1754420 works
I just caught you wanted the number for the Mopar Performance Rock Rails 82215165AB works
Got it - updated front page.The Mopar reinforce tailgate hinge is listed as working. If you are going to do 37's or bigger you will also need the mopar tire carrier for 37 and larger wheels/tire 82215355 and the brake light relocation kit 82215349AB.
That’s the thing though. This tread has shown that several things that “obviously” should fit don’t. One guy mentioned changing the wheel carrier only to find out there’s a speaker hidden in there. I don’t think any of us would have expected that to be an issue. So if that is different, what else about the tailgate might be different? At the very least, that means there’s also extra wiring routed somewhere in there and that alone would make things like your table not obviously compatible. So your post is helpful.I guess we're trying to cover any accessory, even if it's probably obvious it works, so I've got one
