Low_Spark
- Apr 14, 2021
- Washington
- 2021 JLUR 4XE
RokBlokz XL work just fine, installed them front and rear on Wednesday.
I rerouted mine. No custom work. I have Teraflex 3.5" RT3 short arm lift with Falken 35" MT's and Falcon 3.5 aDapt shocks. I had to make minor mods for shocks on passenger front, inner fender on driver front and Stealth Light Bar for sky top.Rear E-brake relocation brackets do NOT work (e-brake body mount is redesigned) and you can NOT relocate the e-brake cables under the cross member.
Therefore, any lift in the rear greater than 2" to 2.5" will need some kind of serious custom work done in order to lengthen the e-brake cables.
Can you help me out with part numbers, etc. See modified front page. Thx!I can confirm these work fine --
-- Bestop Sunrider
-- Carolina Metal Masters dash grab bar ball mount (replaces the bolt, awesome!)
-- Rhino-Rack Backbone System and Vortex bars.
-- Hothead Headliners
-- Blue Ridge Overland Gear gear attic
-- Kicker dash top speakers drop-in replacement for the Alpine system.
-- Grab bar dash tray
-- Mopar front all-weather floor mats work, but the rear ones are too wide. (There's a custom 4xe version that fixes that but is hard to come by.)
Would you mind posting the specific part number for the lift and shocks you picked up? I’ll include on front page. Was this set build / tested for 4XE or did it just happen to work given they way you chose the parts?I rerouted mine. No custom work. I have Teraflex 3.5" RT3 short arm lift with Falken 35" MT's and Falcon 3.5 aDapt shocks. I had to make minor mods for shocks on passenger front, inner fender on driver front and Stealth Light Bar for sky top.
Sweet - any chance you have part numbers handy?Z Automotive’s Tazer Mini works fine. A couple of functions are not available because of the nature of the drivetrain and braking system (no easy burnouts with the front brakes locked).
Z Automotive’s JL front camera DOES NOT fit—but the JT version does. 4xe’s have the same grill as a Gladiator.
I had to modify a couple of thing for fitment of shocks due to reservoir. Measured rear springs before and after install. Had a compression of .25" so I installed a .5" load spacer.Would you mind posting the specific part number for the lift and shocks you picked up? I’ll include on front page. Was this set build / tested for 4XE or did it just happen to work given they way you chose the parts?
Tazer JL Mini: Z-TZR-JLMSweet - any chance you have part numbers handy?
Thanks - front page updated!Tazer JL Mini: Z-TZR-JLM
JL front camera: Z-JL-CAM
JT front camera: Z-JT-CAM
Thanks - updated front page!The KC Gravity Light Bar option will not work on your jeep because they put the charging outlet in place of the pillar mount.
Have you done a write up of how you were able to install stealth light bar with the Sky Top?? Very interested!I rerouted mine. No custom work. I have Teraflex 3.5" RT3 short arm lift with Falken 35" MT's and Falcon 3.5 aDapt shocks. I had to make minor mods for shocks on passenger front, inner fender on driver front and Stealth Light Bar for sky top.
Ha! It’s funny you asked this. I literally like 10min was re-reading his post and say mention of that. There’s a good Quadratec install video on YouTube. I didn't even know this was a thing!! I remember on my JK having the largest pain In the rear with my external light bar. Noise, buffeting, filling in the fins with striping, etc. let along when you had to replace your front window - forget It. The interior installation is super interesting!!Have you done a write up of how you were able to install stealth light bar with the Sky Top?? Very interested!
I’m interested in this too.Have you done a write up of how you were able to install stealth light bar with the Sky Top?? Very interested!
