Skippy477
Pennsylvania
2021 Wrangler Sahara 4xe
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories IMG_1450
Mopar bug and stone guard fits (very easy to install as well)
seannaz
seannaz
Sean
Scottsdale AZ
2021 Wrangler JKUR 4XE, Cyber Truck (on order...)
Ordered A-Pillar light mounts. Looks like they are going to work just fine. Mounts only so far - lights coming in the near future.
I ordered these from Amazon - SEVEN SPARTA 1 Pair Light Mounting Brackets - LINK
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories EB3D8DA1-28A4-4DC8-9F65-8DC23B5E607D
seannaz
seannaz
Sean
Scottsdale AZ
Also received my trail rail dividing rail today. Pretty legit.
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories F405BF3B-D5C4-4AF2-8668-C0D721F84BCB
seannaz
seannaz
Sean
Scottsdale AZ
I can confirm the LOD Armor Lite rock sliders mount up no problem. Got them installed last weekend, including the extra optional self-tapping bolts.
Rock Hard 4x4 Rear LCA bolt-on sliders and Metalcloak's trailer harness slider worked no problem as well.
Another confirmation that the Quadratec dead pedal does not fit. However, I pulled out the grinder and am trying to modify it to fit using some washers and a coupling nut with threaded rod on the firewall stud. Will update if I'm able to get it to work.
Part numbers or links would be awesome for all of these - I’ll add them to the front page. Thanks!
seannaz
seannaz
Sean
Scottsdale AZ
Part numbers or links would be awesome for this - I’ll add it to the front page. Thanks!
seannaz
seannaz
Sean
Scottsdale AZ
REMINDER: Please indicate if the items does or doesn’t fit without any modification. Also, would be super helpful to provide me with part number and a link. I’ve been crawling this thread to try to summarize and bring these posts back as concise details on the front page. Thank you!!
seannaz
seannaz
Sean
Scottsdale AZ
Jeeperz Kreeperz
New Hampshire
2021 JLUR 4xe
67 Designs just released a 4xe-specific Single Ball Base for mounting phones, cameras, etc. Just be sure to order the 4xe-specific one, and not the one for the regular non-4xe JL.
Link for 4xe version: https://www.67d.com/collections/jl-.../jeep-jl-gladiator-4xe-mount-single-ball-base
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories FBEA7412-0C73-4658-80AD-8B796288B8E5
They sent me both driver and passenger versions before they were available on the website, and I just installed them today.
Very simple installation:
1. Remove rubber liner from pocket
2. Remove Phillips head screw(s)
3. Install ball mount(s)
4. Cut rubber liner to fit (I found 3/16” from that third “rib” worked great)
5. Pop in rubber liner
Pics of installation:
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories E96B4D0D-515A-4BF9-A650-9FCB5E1F772C
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories 8F006EC3-FF42-4490-B189-3FD90E908A1A
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories 55C76F4E-E3E7-4580-913F-A776B335248F
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories ECAE75E1-DF52-40ED-92C7-B2CB1E2FF195
Jeep Wrangler JL Jeep 4XE Compatible Parts & Accessories AC84B4B7-B675-40DB-AEFD-24045EF5F096
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
Teraflex HD Forged Trackbar 1754420 works
I just caught you wanted the number for the Mopar Performance Rock Rails 82215165AB works
Sboden
Kansas City
The Mopar reinforce tailgate hinge is listed as working. If you are going to do 37's or bigger you will also need the mopar tire carrier for 37 and larger wheels/tire 82215355 and the brake light relocation kit 82215349AB.
seannaz
seannaz
Sean
Scottsdale AZ
Got it - thx. Confirming that you did the rear track bar. The front track is one digit different. Let me know.
seannaz
seannaz
Sean
Scottsdale AZ
Got it - updated front page.
MaskedRacerX
DT
Florida East Coast
'21 Wrangler Sahara 4xe
I guess we're trying to cover any accessory, even if it's probably obvious it works, so I've got one.
Rough Country Folding Rear Tailgate Table
Fits: 2018-2021 JL/JLU
Part#: 10625
From Amazon:
https://www.amazon.com/gp/product/B094BYCSHR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
(Also available direct from RC)
Fits/installs as designed for 2018+ JL/JLU non-4xe
Got this for the wife when we figured out we didn't have a good place for beverages (and potato salad :D) Nice piece, slick latch setup, doesn't rattle, leaves tailgate vents clear, only mod is drilling out the plastic inner tailgate cover to access some OEM fastener points (an easy 30 minute install). Only $79 vs. the MOPAR part.
Skippy477
Pennsylvania
That’s the thing though. This tread has shown that several things that “obviously” should fit don’t. One guy mentioned changing the wheel carrier only to find out there’s a speaker hidden in there. I don’t think any of us would have expected that to be an issue. So if that is different, what else about the tailgate might be different? At the very least, that means there’s also extra wiring routed somewhere in there and that alone would make things like your table not obviously compatible. So your post is helpful.
