GATORB8
CLT NC
21 JLUR 4xe
GGolds
Gerry
Hartford, CT
Jeep Wrangler 2019 JLU Sahara. 3.6, V6. Mojito with a black hard top. Tan leather. 2019 Jeep Cherokee Limited.
Paramedic
Come on you all - really want to know who has found the answer to a dead pedal. No modifications or fabrication needed. I had a Mountain Off-road dead pedal in my JK and it was amazing - who makes one with a perfect fit for the 4XE??
OK, I took the dead pedal I had on my 19 and then took a 2/2 inch metal corner bracket and mounted it to the dead pedal without the long metal piece that would attach to the bolt on the firewall. Attached one side to the pedal and the other side to the metal bracket on the LEFT SIDE of the inside wall of the Jeep, just inches from the firewall bolt. Now it works perfectly. Few.
capn00
Jared
PA
2004 Wrangler Unlimited, 2021 Wrangler Sahara 4xe
Any pictures?
Very minor gaps on driver side mats near door sill, but better than I have experience in past vehicles with Weathertech previously. Integration of drains holes and utilizing factory drain plugs is great.
bondijoe
NJ
2021 JLU Sahara 4xe - Sarge Green
Can confirm 6CG99TZZAC does not fit on Sahara 4xe. 6CG99TZZAC headlight rings are a tad bit smaller and one of the tab holes is not the right size.
Just ordered 6KM36TZZAA, will update when it comes in. Plasti dipping the originals since I have them off now.
Just seeing if you tried to install 6KM36TZZAA on your 4xe and if it fit? Thanks!
cutandrun
Porsche 911 turbo, Mercedes G550, Rubicon 4xe
After not liking the way Rancho’s RS9000 shocks fit on my stock height 4xe Rubicon, I was going to wait until manufacturer recommendations came down, but I was never good at patience. Last weekend I installed Fox 2.5 reservoir shocks all around and added the Fox ATS steering stabilizer while I was at it. Aside from the replacement axle bracket for the stabilizer needing some persuasion (a known issue), all went on easily. The Fox shocks are slightly longer than the Mopars. Ride is now completely adjustable.
GATORB8
CLT NC
21 JLUR 4xe
Well, damn. Still waiting for the Jeep but just realized the License Plate relocation bracket I ordered for the rear Rugged Ridge HD bumper sits right in front of the rear 4xe badge. Anyone have a non-tire mounted relocation solution? Afraid the D ring mount brackets will interfere with the backup sensors.
RNLROCK
Rich
New Jersey
Wrangler 4XE Sahara
What was the issue with the Ranchos? Curious because I was thinking of getting them for my Sahara 4xe. Thanks.
cutandrun
They were almost an inch shorter than the stock shocks. I did not want to lose any suspension travel. I also found the adjustment knob to be imprecise and difficult to set. I found this shock chart elsewhere on the forum. Very helpful (see the original thread for a link to the google doc https://www.jlwranglerforums.com/fo...gs-suspension-information-chart-matrix.66591/)
Kayphix
Joshua
Fort Collins
4xe
Sold my Jeep Wrangler 4xe due to changing circumstances. I needed a truck for work, so it had to go.
Located in Fort Collins/Denver area if anyone is interested. Feel free to PM for photos.
1) RockSlide Tailgate Table - $200 (paid $250) (Sold by Extreme Terrain) all hardware included.
2) Thinskins Rear door protectors. Unopened and in box
$130 (paid $142 w/ shipping)
3) Bulletproof phone mount for the 4xe - $50 (paid $60) brand new.
tactical_gnr
Taylor
Denver
4xe Rubicon
Long shot here, but you don’t happen to have the hardtop do you?
nelson55917
NIck
Minnesota
2021 Jeep Wrangler 4xE
  • Coyote Mirror for 2018-Current JL & JT (Pair) (Part No: MJL-800) - LINK (DOES NOT WORK)
    • Note: User “Sboden” reported that the charging port interferes with the mounting of these mirrors
I installed the Coyote Mirror above. The passenger side installs no issues at all. The driver side next to the charge port needs a small mod to the piece you screw on. The only reason the mount doesn't fit on the cowl is because the cowl seems to be a bit thicker metal around the charge port vs the passenger side. A simple cut to the lip and the piece goes on perfect. There is still a rigid edge on the bottom of the cowl that will prevent the coyote mirror holder from moving or slipping. Cutting the lip off took all of 30 seconds. Next time I pop the doors off I will shoot a pic. I would recommend, it is a simple mod with a washcloth to wrap the piece in a vice and a hand metal saw.
Jocko
Boston
Hydro Blue 4xe Rubicon
Yes that is exactly the same mod I did to make my Coyotes work! It was super easy because they are made of aluminum! And because it still has the bottom part of the "lip" is stays stable and would still work fine if you ever want to install them on a non-4xe later.
Awarner8
Alex
Nebraska
I went the other route and trimmed the interior of the cowl. No change to the exterior so if they are ever removed it will be unnoticeable.
I can confirm the S&B CAI and functional hood scoops fit the rubicon 4xe.
Icon Vehicle Dynamics
