Jeeper4xe
NC
Wrangler 4xe
Wanting to confirm that the cargo tray for 4xe (part #82215988) does fit. I purchased from BAM in mid June and received last week. However, still not seeing them on their website. I emailed them originally asking about the 4xe floor mats and they sent a quote for the cargo tray as well, though didn’t see it on their site then either, so jumped on the opportunity to order both. I don’t know about current availability but the email contact I used is [email protected] if anyone is looking for the tray and wants to inquire.
millerjl
Chuck
San Diego, CA
JLU Rubicon
Is the wheel backspacing, axle width, etc. the same on the 4xe Sahara as the non 4xe Sahara? Trying to narrow down wheel choices and want to stay close to stock fit under the fenders.
Judy33
MA
1999 TJ
Installed recently both a bull bar (with light bar built in) as well as side steps (removed rock rails because the only thing realistically damaging my cars is my kids). Both took some trial and error (I was the error) and fit perfectly.
Bull Bar was from Extreme Terrain: https://www.extremeterrain.com/barricade-hd-bull-bar-w-skid-plate-20-dual-row-led-light-bar-textured-black-2018.html
Steps were from Quadratec: https://www.quadratec.com/p/go-rhino/1000-series-4-side-steps-jeep-wrangler-unlimited-jl
Did you put the bull bar on a regular or steel bumper? It looks like it takes away some of your ground clearance - is that the case?
PapaJoe
Cary, NC
2018 Jeep Wrangler JLU
Will a 2019 Rubi takeoff steel front bumper fit the 4xe Rubi?
Sethward01
Seth
Central Kentucky
2021 Jeep Wrangler 4xe
Yes--just measured for someone else I saw who asked this question. Just measured mine, and got about 6.25" of backspacing, which is +44mm. Hope this helps!
Sethward01
Seth
Central Kentucky
Anyone have any luck with a Radiator Grille Trim Ring Kit that fits the Sahara 4xe? Mine is black with the silver radiator trim. Im getting it wrapped bright orange in a couple of month and would like to have black accents on the radiator. Ive wanted an orange Jeep since I was in high school, and FCA broke my heart when they killed off Punkin Metallic for 2021.
bkhahn
2021 Wrangler Sahara High Altitude 4XE
Anyone have luck finding a rear LED brake light wheel (3rd brake light within the rear wheel/tire) that works with the 4xe?
millerjl
Chuck
San Diego, CA
JLU Rubicon
What is different about it? The speaker? Was going to get one for mine on order…
Sethward01
Seth
Central Kentucky
I just had the swing gate reinforcement kit and spare tire relocation kit installed on my 4xe. I assumed the relocation kit would move the 3rd brake light higher above the spare tire. But the techs moved it into the spare tire with the part below. Looks cool, but was unexpected.
https://store.mopar.com/oem-parts/m...-light-chmsl-relocation-kit-82215349ab?c=az0x
bkhahn
Wasn't sure if the speaker impacted it or not. If I don't hear anything I'll end up buying one and giving it a try, but wanted to see if someone else had something that for sure would work.
Jeeperz Kreeperz
New Hampshire
2021 JLUR 4xe
Jeeperz Kreeperz
New Hampshire
2021 JLUR 4xe
I can also confirm the Genesis Dual Battery System for JL fits just fine, but it did require that I repurpose/modify the OEM battery tray bracket to support a couple of hybrid battery coolant parts that don’t exist on the regular JL.
Here’s a thread I created that shows the step-by-step: https://www.jlwranglerforums.com/fo...ual-battery-system-in-4xe.76402/#post-1589952
Definitely adds some time to the install - but if you’re competent enough to take on the install in the first place, then this added mod should be easy enough for you. You will need drill, tin snips, vise, hammer (none of which are needed for the dual batter install itself).
Ratiogear
Justin
DFW
2021 4xe Rubicon
TopLift Pros
