Jeep 120v Charger stopped working
alpha1847
Angelo
Boston, MA
2021 Wrangler 4xe
I've had my 4xe for about a year with no charging issues to date. Out of the blue, the factory charging cable is not working. I get the green light on the charger brick, but the Wrangler shows the red indicator of a charging issue. I know the power is fine. Any ideas? If the charger was bad, I assume I wouldn't get the green LED light, right? Any ideas out there? Cheapest replacement cable is $200, so that's the last resort.
silverheep
Fort Collins, CO
2021 JLUR4xe
Have you tried charging at a public charger?
If you were able to charge with one, you’d know the Jeep is okay and there’s likely an issue with your charger.
I wouldn’t necessarily say the opposite result (your Jeep not charging on a public charger) is conclusive as many of the public chargers in my area are not reliable.
Of course - if your dealer is nearby, probably easiest to just stop by there!
alpha1847
alpha1847
Angelo
Boston, MA
2021 Wrangler 4xe
So, public charger #1 had the same result. Sounds like s stop at the dealership is in my horizon. Damn.
BXFXJeep
Toronto, ON
2021 4xe Sahara
While we are on this, what is the warranty on the 120v charger that came with the Wrangler?
I never used mine, I do not have anywhere to plug it in.
alpha1847
alpha1847
Angelo
Boston, MA
2021 Wrangler 4xe
Can't find answer anywhere....
