nositting
So I crawled under my JLU tonight and it looks like I have a leak. The bottom of the vehicle is dry but there's definitely some type of fluid that is on/has been on the driveshaft. It doesn't cover the whole thing but a good portion. It looks like the culprit is a tiny leak from the transmission up higher. also looks like there's a tiny transmission leak down lower however this is lateral to the driveshaft and most likely not the offending leak. neither one of these are major as there's never a drop on the garage floor but it's only 3 months old. anyone else have this? i'm guessing i need to go to the dealership. what kind of hassle can i expect if it needs some new gasket or transmission work? would this be covered under warrantee? there's no lights on the dash and everything works perfect. any thoughts? thanks!
