Outrun
Just get a gasket that doesn't require all this extra work. A torque wrench is easy to utilize.Is removing the cover the best way? No. You can identify premature wear, make sure you get more fluid (but not all) out, identify potential problems, etc. by removing the cover. But not everything.
The absolute best way is to remove the axle and disassemble everything. Then measure all teeth on all gears with a micrometer, measure thickness and wear on things like bearings and clutch packs, replace common wear items and one-time-use items (like crush sleeves), and reassemble in a clean environment.
Obviously, I'm being a sarcastic here - but I don't want to be a jerk. No one is going to do all that every time. The question is cost vs. benefit. Of the thousands of people who are regularly changing their fluids, how many are going to actually find a problem? Three? Four? A dozen?
Moreover, the harder you make something to do, the less likely you are to do it. If you can do a task in 5 minutes, then chances are good you will do it when you need. If it takes you 30 minutes or an hour (buy new gasket maker, remove bolts, scrape old gasket off, clean surface, apply new gasket material, reseal pumpkin, etc.), then chances are fair you aren't going to do it as often.
Also, because it's more likely you will be changing the fluid often, the chances of any of those bad things (shavings, water, etc.) are greatly decreased. And you can always inspect your fluid that is removed for those things.
This thread was started because Jeep is getting rid of drain plugs. Well, a vacuum pump will remove just as much fluid (or more) than a gravity drain.
The only real difference between the 2 is that you might be able to drain a few ounces more fluid by removing the cover. If you leave 2 ounces of old fluid, you are going to have 97% new fluid in the diff. Considering that during an oil change you are left with 0.5-1 quart of old oil in the engine, meaning you are only getting 75-80% new oil, 3% isn't terrible at all.
But, in order to get those last few ounces out, you are introducing a lot of uncertainty - did you put the gasket sealant on properly? Did you torque all the bolts properly? To me, it's just not worth introducing those new points of failure to potentially prevent something that happens <1% of the time.
If somebody is too afraid of or doesn't trust themselves in the first place to do these simple things probably best to let a mechanic do the work.
Also, this is not something done often.
