John VonJeep
Middle of Nowhere
Many
Checked my XR this morning. The rumors are true. The front Rubi diff no longer has a drain plug. I wonder if this is a parts-related change, or a design-related change. In any event, I don’t like it.
bjm00se
Bullwinkle
Lifted Tacoma Reg Cab, JLUR 6sp ordered 11/3/21
Glad you brought up the point and counterpoint.
Not sure it's all Rubicons. I *think* it's only been seen so far on eXtreme Recons.
I have a Rubicon on order. It would actually make me happier if it's done this way.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
Of course, this is the argument for removing it:
This is exactly why. It’s not that hard to loosen the bolts to drain it, plus you can clean it better that way.
AcesandEights
Aces
So. Oregon
2021 Jeep Rubicon 2D
I would always remove the diff cover anyway. Seems odd to have a drain plug on something you'd want to inspect anyway, especially in the place where it is most likely to be damaged. Makes it quicker for the quicky-lube places, but not an advantage for someone that does their own work and wants to look things over.
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
I see no reason for a drain plug on a diff. In fact the Jeep's are the only vehicles I have ever seen with a drain plug. I find it odd and concerning that it would put someone out to do something as simple as removing a diff cover to drain fluid.
ekim
NJ
2000 TJ
Ha try that on a Ford 9" style diff :).
gato
New England
2021 JLUR
Murphydog
Seattle
2014 BMW X3, 2021 JLUR ordered 6/10, delivered 9/2
I will double check, but I think it was missing from my Rubicon as well. V6 eTorque delivered in early September.
OK - can of worms here, quick glance at the maintenance plan it says to change front and rear axle fluid at 40,000 miles if using your vehicle for police, taxi, fleet off-road or frequent trailer towing.
it doesn't seem to list any light duty (my words) interval for changing.
So is 40K a reasonable mileage to change front and rear diff fluids?
OllieChristopher
Southern CA
We are not talking a Ford 9". In the case of those (and a lot of Toyota diffs) then it is a very simple third member removal. Only difference is having to remove the driveshaft.
guarnibl
Scottsdale
'21 JLUR 392 XR, '21 JTR, '21 JLR, '09 JK
I change mine annually given I wheel quite a bit. I'd argue if you do, and enter water -- you should change more frequently. At the same time, potting the sensors as preventive is a common thing owners should consider doing early on. In my case, my lockers were already starting to have issues engaging after 3k miles. Mine will get potted after break in at first oil change which I'll be doing at 3k.
Tri-City Jeep
