CarbonSteel
Wanted to post this as well. I asked ZF what the difference was between Lifeguard 8 and Lifeguard 8 ATF (fluid that replaced Lifeguard 8) and the answer is there is zero difference.
It was a name change in conjunction with a supplier change:
Sent: Tuesday, January 3, 2023 06:18
To: CarbonSteel
Subject: Your ZF Services Request #967026
To: CarbonSteel
Dear CarbonSteel,
for further processing of your request, we kindly ask for the following information:
The fluids are the same. Both are accepted fluids for the 8hp and the Audi 6hp transmissions. We had a supplier issue and when we used a different supplier we had to provide the name ZF Lifeguard Fluid 8 ATF..
Your question to us:
Can you tell me what the difference is between these two? I know that you published an article (https://aftermarket.zf.com/us/after...il/41be9647-b9cf-4fb1-920f-2fabb2c4be8a/en-US) about supply chain issues, but are these fluid exactly the same, just with a rebranded name?
Thanks!
CarbonSteel
Please reply to this mail using the “Reply” button of you mail client – DO NOT CHANGE THE E-MAIL SUBJECT.
For further questions or updates please contact ZF Services North America, LLC., telephone: +1 847 478 6868.
Always provide your request ID when contacting us regarding this request, please.
Disclaimer:
THE INFORMATION CONTAINED HEREIN IS PROVIDED TO THE REQUESTOR ON AN "AS IS, WHERE IS" BASIS, WITHOUT WARRANTY OF ANY KIND (EITHER EXPRESS OR IMPLIED), INCLUDING BUT NOT LIMITED TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A SPECIFIC OR GENERAL PURPOSE AND THOSE ARISING BY STATUTE OR BY LAW, OR FROM A CAUSE OF DEALING OR USAGE OF TRADE. ZF DOES NOT ACCEPT ANY RESPONSIBILITIES FOR ANY LOSS OR DAMAGE WHATSOEVER ARISING FROM ANY CAUSE WHATSOEVER IN CONNECTION WITH THE INFORMATION PROVIDED HEREIN, INCLUDING WITHOUT LIMITATION, ANY DIRECT, INDIRECT, SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES OF ANY KIND, WHETHER ARISING UNDER BREACH OF CONTRACT, TORT (INCLUDING NEGLIGENCE), STRICT LIABILITY OR OTHERWISE, AND WHETHER BASED ON THE INFORMATION PROVIDED HEREIN OR OTHERWISE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
Kind regards
Your ZF Service Desk
