Is your JLUR level side to side?
JeepNomad
Andy
TN
2020 Ocean Blue JLUR
Retired Navy
I have had my 2020 JLUR for about a month now. I replaced the front OEM plastic bumper with an LOD steel one. I noticed that it looked crooked (lower on the passenger side) and thought I messed up installing it. Turns out the whole jeep leans to the passenger side when empty. It measures an inch lower from the front fender to the pavement. Is this normal? Do they set it up this way thinking that the when the driver is in it will level out?
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
I don't own a JL, but the JKs also have a slight list. It's normal.
JeepNomad
JeepNomad
Andy
TN
Retired Navy
WagzDad
Carroll
South Louisiana
It’s a function of which side she is riding on.
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Studies show the average Jeep driver weighs 325 pounds so the suspension is a little higher on driver side to compensate.
average is 325 lbs. seriously???? Are you sure that is right?
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
If it's more than 6 inches, you should get that checked out :bandit:
Also if you're 325 pounds and not an NFL lineman, you should probably get that checked out too.
JeepNomad
JeepNomad
Andy
TN
Retired Navy
Wow, this thread went sideways really quick. LOL. If 325lbs is the average Jeep owner I need to start eating more. Me and the girlfriend together are less than that! If I add the 2 dogs in then we are right about average!
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
That’s going to suck driving with all of them sitting on your lap ;)
4xFUN
Scottsdale AZ
2020 2-door Rubi. 2023 RAM TRX
I was lucky-my JLR was dead level side to side (gas tank near empty and sitting on pretty level garage floor) until I did my Mopar lift and found she was 3/4 inch low on passenger front...She is back to just over 1/8 inch low in the front (Mopar, at least on the 2-door instructions have the two front spring part numbers switched L to R, longer springs do go on passenger side) while the back is still just over 1/4 inch low (haven't addressed that just yet)
An inch low on passenger side on a new, stock Jeep, seems excessive...Using your VIN, ask your dealers parts department to look up and print out the LF, RF, LR & RR spring part numbers and compare them to what is actually on your Jeep. If they match, ask you dealer to take a look at the lean. If all else fails, Teraflex makes front and rear 1/2 inch spacers for leveling...
Drytellsr
jacksonville, florida
Maybe when you fill your tank, it will bring it level, it's on the drivers side. See what it looks like after you fill up. Mine looks quite normal and I always keep a full tank.
4xFUN
Scottsdale AZ
By the way, did you spend much time on Birdfarms?
JeepNomad
JeepNomad
Andy
TN
Retired Navy
Thanks for the info, I worked on P-3's most of my career, they are land based so no carriers.
JeepNomad
JeepNomad
Andy
TN
Retired Navy
I thought about that so filled up the tank... same gangsta lean to the passenger side.
