Is this where Tazur plugs in?
shekmark
Manasquan, NJ
Yes
I just looked under my dash for first time because my new Tazer is still in the box. Is this the port it plugs into ?
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
It’s behind there and higher. Two black plugs need to be unplugged and the tazer placed in line
Brett
AnARcHy
Bob
North Carolina
2018 Jeep JLU Sahara, 2003 Toyota Tacoma, 1990 Toyota Truck, 1998 FLSTC
Firefighter
It depends on if you have the Tazer JL, or the Tazer JL Mini/Lite version. All of them require you to reach up about 6” above the part in your picture (which is the OBD port) where you will see two smaller plugs. Unplug those and plug them back into the Tazer Mini/Lite, or if you have the Tazer JL there is a part that those plugs go into.
If you have the Tazer JL, you will plug the Tazer into the OBD port that is in your picture.
I hope that helps.
shekmark
shekmark
Manasquan, NJ
Yes
Thanks. I got the lite. I will look up there higher. Its off to the side like this port but higher.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
AnARcHy
Bob
North Carolina
Firefighter
Yes, directly above there, about 6” higher behind the dash. Right where the metal brace is, that is going to hinder you in getting those plugs out!
jeepdabest
Bobby
Arizona
2019 JL Sahara
It's for the Keurig P150 with OBD connector. Never add water. Mine is plumbed directly into the radiator.
