longfiredragon
Hello all, is this what I turn to center the steering wheel?
Thanks.
Thanks.
Don't turn that one at all. That is to set toe and is called the tierod.Hello all, is this what I turn to center the steering wheel?
Thanks.
It's the link connected to this arm:Ok, thanks. Not sure witch one that is but I will Google it.
Are you sure? Lol.Got it. Thank you guys!
Nice. It'll take a few tries to get it right. Take the 15mm wrench with you on the test drives. That way you don't have to return to the garage to make an adjustment. Just pull over, adjust, and keep going.Lmao. Yep already adjusted. Going for test run.
A full alignment is not needed for a lift unless you're above 2-2.5". Even then, there's nothing they can do without adjustable arms. No reason at all to pay anyone to adjust the steering wheel. It's literally a 10 minute job with a 15mm wrench.Why is the steering off center? Did you lift it? If yes then take it to a shop and get an alignment and ask them to center the steering wheel in the process.
I've been on rock crawling runs where a Wrangler's wheel got knocked off center like that. Seems to be fairly common.Why is the steering off center? Did you lift it? If yes then take it to a shop and get an alignment and ask them to center the steering wheel in the process.
This is very common. When the Jeep is new, things are tight. As you use it, there's a phenomena called Tolerance Stacking.Mine is off a little also. I did not lift it I noticed mine was off after playing in some rocks and trying to turn. Curious what caused it. I dont believe the drag link would spin or skip threads, also dont buy that the pitman arm would jump splines. Is there something inside the steering box that skipped?
