Garemlin
Fixed itThe link isn't working
This one is fine. It's a remake of the UV-5R. If you use CHIRP to program the UV-S9, you'll have to select UV-5R as the model number.
They are basically a blue Baofeng with fewer features/capabilities. Oh, and they are much ore expensive.Are the handheld "Rugged Radios" any good ?
This is absolutely true about Rugged. They are way over priced Baofeng radios. They're marketing may lead you to think they are great radios, but they're no better. They come pre-programmed is all.They are basically a blue Baofeng with fewer features/capabilities. Oh, and they are much ore expensive.
That little GM 30 I posted blows them away. I'd take a Baofeng over them, too.
Ok this will be my first radio. I have no idea what CHIRP is. LolThis one is fine. It's a remake of the UV-5R. If you use CHIRP to program the UV-S9, you'll have to select UV-5R as the model number.
I thought CHIRP was going to be the answer but apparently it only work with old versions of IOS. It seems like all radios are stuck using a lot of old tech. Seems like a big opportunity.The Baofeng UV-5R Two Way Radio (technically a portable HAM radio) operates on both FRS and GMRS frequencies. It's a solid radio and goes for about $25. You don't need a license for FRS. To use GMRS, you need an FCC license which is easy to get, only $85 for 10years/no test.
You can use CHIRP to program it and the app works on a Mac.
Yes it has already been lowered to $35/10yr but the FCC site has not updated yet, and do not even begin to think it will happen any time soon. Thats our snails pace, inefficient, horrible excuse for a gubberment at work. Especially when there is more money in it for them for their ineptitude and feet dragging.In my researching GMRS radios I read they were lowering the license fee to $35.
I'm his favorite viewerLook for “notarubicon” on YouTube. He’s got more info on GMRS than you’ll need. Reviews, programming, etc.
From my research, you will need the software that comes with the radio or a third party software package like “CHIRP” in order to make firmware updates and possibly some settings. I’m not planning on buying an expensive radio if I can never update it because I use a mac.You see u didn’t even know that I needed to connect it or whatever to make software updates?
I'm still using CHIRP with MacOS 11.6. I would only download it from the CHIRP site and proceed with caution.I thought CHIRP was going to be the answer but apparently it only work with old versions of IOS. It seems like all radios are stuck using a lot of old tech. Seems like a big opportunity.
From the download notes: Application Security in MacOS 10.15+ (Catalina)
Unfortunately, Apple has made significant changes in 10.15 which cause major issues for independent software developers. CHIRP is significantly impacted and the future is unclear.
